Does it matter which vacuum port u hook
Discussion in 'XJ Technical Chat' started by volsrock1963, Jun 15, 2025.
  1. volsrock1963
    volsrock1963 Member
    Kansas City
    Does it matter which vacuum port u hook the petcock vacuum hose to? And does it matter how long it is?
    I have a slight fuel leak above the carbs so I am going to replace the hose and clamps on the petcock
    82 Seca 750
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    It doesn't matter at all.
  3. volsrock1963
    volsrock1963 Member
    Kansas City
    Can I loop the hose from petcock to carbs if I have to?
  4. Huntchuks
    East Rochester, NY
    Not sure what you mean by "loop" to carbs. You cannot connect to carbs. Just make sure it is not kinked or you might not get enough vacuum to operate the diaphragm in the petcock.
  5. hogfiddles
    Correct.
  6. Dave in Ireland
    Ireland
    There was a notion going around if you interconnect the vacuum ports you could do some kind of YICS system, but it's a load of bollocks.
    Franz and Brhatweed like this.
  7. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    YICS is a carefully placed port that imparts a swirl on the incoming air/fuel charge behind the intake valve, interconnecting the vacuum ports on the intake boots will do nothing but close up the holes. As Dave in Ireland pointed out it's a load of bollocks.
    hogfiddles likes this.
  8. Dan Gardner
    Minneapolis, MN
    Nevermind the bollocks…
  9. hogfiddles
    You are also correct.
