DOES THE XJ650 XJ750 GAS TANK FITS THE XJ1100
Discussion in 'XJ Modifications' started by oobondooo, Dec 15, 2016.
  1. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    HELLO i just got another xj1100 since i sold my old one due to a family problem but this one is missing the gas tank i found 1 on eBay for 195 but doesn't have the fuel thing and a hole for the gas level , i dont remember if the xj650 had the gas level or the holes in the tank but i realize that the xj1100 has 3 holes on the tank and the gas cap hole i wanted to know i the gas tank from the xj650 or the xj750 fits the 1100 ,sorry for the question im just trying to save some cash .
    there are some pics of the bike everything is there except the gas tank the plan is to build it back just like my old one
  2. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    can anyone help me please
  3. oobondooo
    oobondooo Member
    MIAMI FLORIDA
  4. francois maltais
    francois maltais New Member
    moncton
    Looks like my 650 seca frame but I wouldn't buy based on my thought!
  5. k-moe
    No. No fit without cutting and welding.
  6. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    cutting and welding the tank of frame ? i heard the 650 750 1100 are the same chasis
  7. mlew
    mlew Well-Known Member
    Apex, NC
    XJ11 tanks are much larger than 650/750 tanks and the chassis are entirely different. The XJ11 and XS11 share a similar frame. The XJ11 holds almost 5 gallons, around 3 for the others. You'll have better luck fitting a XS11 tank instead, even than some slight modifications to the tank will be needed to the mounting flanges.
    Don't ever cut a frame to fit a gas tank, cut the tank to fit the frame.
    Your XJ11 find is missing more than seat and tank. I don't see any carbs, gauges, mufflers, air box, side covers, headlight or turn signals. Its going to take quite an investment in parts to get that one road ready . Look for another parts bike and maybe with the two you can put one together.
  8. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    i would never cut the frame thats why i asked i didn't know the tank where different thats why i asked , im not planning in using side covers gauges turn signals, the one i had before was worse the dummy before me had broken the stunds for the headers try to drill them and completely mess up i was always putting new ones he had no jets lol and i made it work little by little im post some pics spend like 900 total.
  9. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    more
  10. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    more 2
  11. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    final
  12. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    i also saw that 1100 have doual pet cocks? with dual outlets 4 outlets totals i guess thats because the size of the engine that needs more gas , some of the comes with a single pet cock 4 outlets how i know witch tank is witch
  13. mlew
    Apex, NC
    The reason for the double petcocks is the high center tunnel of the gas tank to fit around the frame. The XS/XJ11 frames have a wide double backbone. There is at least a quart of fuel available on each side of the tank. Triumph did the same thing back in the 60s and 70s on some their bikes.
    The dual outlet are on/reserve and prime. The XJ11 used a single vacuum fuel valve which was fed from each side of the tank, the prime function bypassed it.
  14. hogfiddles
    Nowhere near the same
