Drive shaft oil
Discussion in 'XJ Technical Chat' started by nickbrit16, Jun 17, 2015.
  1. nickbrit16
    nickbrit16 Member
    Ohio
    Is it recommended to change your gear oil when the bike is warm or does it matter?
    Thanks!
    Dosen't matter. Warming just speeds up the draining (and finger burning) part of the process.
  3. nickbrit16
    nickbrit16 Member
    Ohio
    Ok, thanks k-moe!
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I know we spend hours debating the right oil for our wet clutches, but is there a type of gear oil we should be using in the rear end? I was gonna pick up one the other day, but the bottle said it was formulated for use with limited slip differentials. I know only one wheel spins when a motorcycle does a burnout, so there's no LSD back there,;) but does it make a difference in the gear oil selection?
  5. Rod1
    Rod1 Member
    San Luis, Argentina
    Manual says grade 80, some ass change mine with a grade over 100 (I guess) and blew the oil retainer...
  6. nickbrit16
    nickbrit16 Member
    Ohio
    I'm using Bel-Ray hypoid gear oil - 80W-90
    BaldWonder likes this.
  7. Rod1
    Rod1 Member
    San Luis, Argentina
    I don't know about that 90 at the end, but all the rest is exactly what manual says.
  8. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    I've got the same weight in mine, but different brand.
  9. k-moe
    You don't need the LSD additive pack, but if you have another use for that gear oil and are buying some anyway it won't hurt to use it.
  10. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    RED-58204 Heavy weight shockproof from Summit Racing.
  11. k-moe
    Brand doesn't matter. API rating and viscosity does.
    FSM and Haynes both call for GL-4 80 or 80W/90.
    The question of whether or not there are any zinc, brass, or copper plated parts in the XJ final drive has come up before. I have still not bothered to tear into one, and unless someone who has can chime in to verify, I will continue to recommend using a GL-4 oil over a GL-5 since GL-5 oil has sulfur compounds that will damage zinc, brass, and copper parts.
    The Redline gear oil referenced above carries an "exceeds GL-5" designation.
  12. MattiThundrrr
    Thanx guys!
