Duel Double Barrle Carbs?!
Discussion in 'XJ Modifications' started by LoneWolf200242, Mar 24, 2009.
  1. LoneWolf200242
    LoneWolf200242 New Member
    New Hampshire
    I been thinking how nice it would be to ballence and tune two double barrel carbs comming out each side of my xj 550, I would assume it would be much like going from a single carb on a VW to a duel carb set up, but I havent seen any kits out and about for a set up like I'm thinking. Hell I'm sure I can make the barrels if there isn't a nice kit available, but what I really need to know is what can I replace the inline 4 carbs with? My bike is a 1981 XJ550H Maxim, I can't remember if i have the hitatchi or makuni carbs though, but if any one has some knoweldge they would like to share it would be appreciated.
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I'm still waiting for the member to get the fuel injection down to a kit form so I can throw all my carbs in the aluminum recycle bin. Or better yet sell them on ebay so someone else can spend hours and hours cleaning and adjusting.
  3. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Your bike has Mikuni's on there, and if you put enough/money you could do it. People have gone over to fuel injection, and I think some one has tried a 1-4 manifold with a throttle body style fuel delivery system.
    But your never going to find a kit, they basically don't make and 'kits' for these bikes that aren't stock.
  4. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    It's been done on 750 Hondas. Infact there is a web site that actually sells the dual carb setup for 750 Hondas that involves two larger single carbs mounted on 2-into-1 intakes. I'd like to see that kind of set up on mine. I'm sure it can be done. I don't know just how much it would effect the performance however. I'm assuming it would not have the same power band it does now.
  5. LoneWolf200242
    New Hampshire
    PainterD if you can remember the website that would be awsome, I'll see what I can google up. Also Ace, thanks for tip-off on fuel injection, never thought of doing that, I'll have to look into that too while researching.
    Thanks again.
  6. midnightblu
    midnightblu Member
    Austin, TX
    here is an interesting thought...a DHLA 40 or DHLA 45 Dellorto Side Draft Carb (i wish i could remember off the top of my head the port size for the intake) i have a pair of 48's that i run on my Rotary Truck. it would require some modest modifications but i assure you you wont find a better carb.
