Dyna coils on an 750?
Discussion in 'XJ Modifications' started by Mathius, Sep 3, 2016.
  1. Mathius
    Mathius Member
    Alberta
    I have read about a few people running these coils on other forums.
    But info is sketchy at best...
    I'm curious which ones to use? They are way cheaper than factory coils (mine are pretty tired), but they make 3ohm & 5ohm coils.
    Which ones are compatible with our bikes wiring??[​IMG]
  2. Toomanybikes
    Tsawwassen bc
    Dyna catalogue lists correct ones for factory electronic ignition systems
  3. XJ550H
    www.xj4ever.com sells coils and mounting kit for your bike no guessing on what you need
  4. Mathius
    Mathius Member
    Alberta
    I checked it out, his price on those coils isn't that bad.
    The ones we need for these bikes are the 3ohm ones.
    According to the dyna catalog, the installation kit is discontinued. Unless he has some old stock.
    I might message him?
    I think he's mad at me though, cause I questioned the high prices on his Jets.. lol
  5. luvmy40
    luvmy40 Member
    Y-Town, OH
    Len's coils and mounting kits work like a charm. You have to relocate the signal flasher but that's easy.
  6. Polock
    you need 3 ohm coils. notice the direction of the mounting holes on those, compare it to yours.
    other than that, i've run them for two years with accel copper wires they work fine
  7. Mathius
    Mathius Member
    Alberta
    Did you make your own brackets?
    I was looking at the way they mount, it points them sideways.. lol
    The fact that the installation kit is discontinued makes me a bit leary. It might be better to just wing it.
    Plus I'm cheap..
  8. XJ550H
    buy the mounting kit from chacal ask him if it fits,
  9. k-moe
    I'm pretty sure that the installation kit that Chacal sells is his own in-house item, and is meant for all the XJ550, 650 and 750 models.
  10. XJ550H
    most likely and is used with the dyna green coil from what i understand his catalog to state
  11. chacal
    Correct, but it's really for the 650, 750 air-cooled, 900, and 1100 models.
    Correct!
    k-moe and Mathius like this.
  12. Jetfixer
    An alternative is 81 thru 83 Honda CB750 coils....you can buy brand new from Cycle Recycle part 2 39.95$ each these coils mount just like stock. The plug wires are replaseable they also sell wires and plug caps.I've been running them for over 1000 miles of trouble free use.
  13. Mathius
    Mathius Member
    Alberta
    Interesting..
