Dynatek Coils
Discussion in 'XJ Technical Chat' started by rtanner, Oct 13, 2009.
  1. rtanner
    rtanner Member
    South East Michigan
    Has anyone installed Dynatek coils in an XJ or know the ohm rating of the standard coils? I have a set of DC1-1 coils I have considered installing in my XJ 650. They are 3OHM units. Any thoughts?
  2. dawsoner
    dawsoner Member
    Boulder, Colorado
    I installed them on my '86 Maxim X. They work very well. Hap's page has a lot of information on them (and installing them on an X). They would be very easy to install on a 650
    http://www.maxim-x.com/dyna_coils.html
  3. schmuckaholic
    California
    Absolutely -- had a stock coil fail on my 750 Max, and stuck in a set of Dynas from Chacal. It starts SOOOOOOO much easier now.
    If you get the coils from Chacal, you'll get a copy of the writeup I did that meticulously and painstakingly details the process.
    XJCD says 2.5 ohms.
    Oh, you have them already? Send Chacal a PM and see if he'll send you a copy of the file.
  4. bostonXJ
    bostonXJ Member
    Mansfield, Ma
  5. JameyP
    JameyP Member
    Princeton, NC
    I also put them on my 86 X following the directions from Hap's page. Very easy install.
  6. Robert
    30 ohm coils on a system designed for 3 is not a good thing folks. I don't recall which P/N is the ticket for the earlier XJs but I'd be looking to install the correct resistance coils so as to avoid frying my ignition system.
  7. smurf667
    smurf667 Member
    Newark, Nottinghamshire, England
    The Dyna dc1-1 are 3 Ohm coils Robert, not 30 Ohms, there was no space between the 3 and the OHM, which made it look like 30 Ohm, and the stock coils are 2.5 Ohm. It's ok going slightly above this rating, but going below is a no-no as it will damage your TCI. The dc1-1 run fine on the bike
    Pete
  8. Robert
    Whew, glad I can't read...mommy has been bugging me to see the optometrist.
  9. Erman
    Erman Member
    Oslo, Norway
