Easy Front Fork Question
Discussion in 'XJ Technical Chat' started by apfenech, Jun 8, 2015.
  1. apfenech
    apfenech New Member
    Utah
    What are the numbers on the top of the fork of my XJ 750 Maxim for?
  2. Beekman
    Beekman XJ Grasshopper
    Erin, Ontario
    Probably spring preload. I don't have a 750 though so my forks don't have that
  3. k-moe
    That is for adjusting the compression damping. 1 is soft, 4 is stiff. Solo rider would be set to 1 or 2 depending on your weight.
  4. apfenech
    apfenech New Member
    Utah
    I knew that would be a simple answer like that but just wanted to be sure. Thank you
  5. apfenech
    apfenech New Member
    Utah
    K-Moe, I'm assuming that the rear should follow the same settings? I'm a small guy at 150; a 1 for the minimum?
