elcetrical box?
Discussion in 'XJ Modifications' started by Proar, Aug 9, 2016.
  1. Proar
    Proar Member
    Denmark
    so ive a new speedometer and ignition. my play is to make a custom ignition location with a toggle switch code system. and im thinking that a good idea is to make a wire/electrical box to collect all this neatly. and yes i am planning on trying pods, but im stíll keeping the original box for same reason. so i would need one that might fit the original design. has any one done this or a simple method maybe? should it be closed if i have to come up with one on my own?
    and since this is new ignition key and all that would it be best if i use the simple wiring harness diagram and make my own? or should i try to use the stock instead? the speedometer is an electrical one (http://www.ebay.co.uk/itm/321714883499?_trksid=p2057872.m2748.l2649&ssPageName=STRK:MEBIDX:IT) is has difrent kinds of sensors, should i try to find a convert switch? im also play with the thoughts of relocating it the the engine so yeah more modding there?
    hope you guys can help
    proar
    1982 yamaha xj 750 seca
    there is a member who use a card reader hooked to relays as a key.
