End of my rope xj700 no fire...
Discussion in 'XJ Technical Chat' started by Turbobob23, Aug 17, 2016.
  1. Turbobob23
    Turbobob23 Member
    Fredericton N.B. Canada
    I know , you've heard it all before , check previous threads , etc, etc...I've done all that on my sons xj700 and cannot get fire at all. I've replaced the ignition box, tried coils, new rectifier, new harness(checked continuity), tried to find voltage values for all the sensors,coils,boxes. Just won't spark! This is year 3 after we rebuilt his bike and it ran when we bought it. He was 16 and his first vehicle. Total rebuild and nothing. Very frustrated. Just want my son to benefit from his own hard work.
    I'm desperate and need help. My time is limited so I need answers for him....please someone help.....
    Bob
  2. 1982 xj 550
    1982 xj 550 New Member
    Loganville GA
    I am literally in the same boat as you I have a 1982 xj550 that I have completly checked the harness, all relays, coils, fuses etc and I don't know where to turn
  3. Wagy
    Wagy Active Member
    PA
    Shortly after i got this very used '85 700 maxim , it ran fine for a couple of months then one day with no warning , it just would'nt start and had no spark. At that time I had absolutly no expierince on really any bike and had not found this site till much,much later, So anyway someone gave me advice that theese bikes were known to have the pick-up coils go on them pretty often. Got one from E-bay, changed it myself and has run ever since. I am talking about the secondary pick-up under the stater cover. Dont know if you checked or not, i did'nt even know how to test the old one, just got lucky, but if you did'nt check, test or change, it might be worth a try. But to be sure, there are alot of guys on here that know more than i ever will. Good luck, I feel for you and your son's situation, Have done two total restorations with my boy now, so I know how you feel.
  4. MiGhost
    MiGhost Well-Known Member
    One spot that often gets overlooked in a no spark situation is the handle bar.
    The control switches are grouded through housing to the handle bar.
    A simple test would be to run a ground wire from the frame to the switch housing.
    If you repainted the frame make sure all grounds touch bare metal.
    ~Ghost
  5. 1982 xj 550
    Loganville GA
    I found this video very helpful
    Stumplifter likes this.
  6. Jetfixer
    3 thoughts side stand switch, or as Mi Ghost said the handle bar kill switch. Or have you upgraded fuse block? and if so are all the wires connected as per wiring diagram? oh wait the X has fuse block under gauges correct? When I say check , I mean with an Ohm meter ,check for voltage as well as continuity ,resistance . Carefully check TCI plug for melting at plug, as well as at the coils. When you stated you replaced coils what about caps on the plugs? Check ALL the grounds for corrosion. Sorry I don't mean to get overly technical , just my aviation back ground .
  7. hogfiddles
    The 700 has fuses in the cluster, but there is a fuse under the seat, too----
    Jetfixer likes this.
  8. Turbobob23
    Turbobob23 Member
    thanks for all your responses guys! I've checked all this but , am going back to recheck everything to be sure again. The video was informative in the method of testing so that made me think to recheck again. I'll keep you posted with results.
    Thanks again , Bob
  9. Turbobob23
    Turbobob23 Member
    Update...found I think an issue with the side stand switch. Can't get resistance one way or another so I by passed that. Still no fire. Tested the coils , primary and secondary and they're good. Got to the little black plastic relay right beside the TCI and couldn't get a click from it no matter how I connected power across the tabs. There should be some sort of click to indicate activation right? so That's where I am so far. If you have any input , I more than welcome it.
    Oh and there was a power problem with the 30A fuse under the seat so I replaced the wire and assembly with updated wire and blade fuse.
    Thanks , Bob
  10. MiGhost
    Unless I am mistaken. That relay by the TCI should be the side stand relay, and it should click when the key is turned on.
    ~Ghost
    Turbobob23 likes this.
  11. Rooster53
    From Lens Post The Ultimate Relay, Switch, Sensor, and Diode Guide:
    http://www.xjbikes.com/forums/threads/the-ultimate-relay-switch-sensor-and-diodes-guide.27543/
    XJ700 and XJ750-X models
    Flasher: combined with ignition cut-off relay.
    Flasher canceller: combined with ignition cut-off relay.
    Starter motor solenoid/relay: attached to and centrally behind the battery box.
    Starter/Ignition cut-off relay (no color): behind gas tank on frame tube cross-brace.
    Sidestand (kickstand) relay (blue): under left side cover, above regulator.
    Headlight relay (yellow): not used.
    Main fuseholder: behind frame crossbar, behind the battery.
    Diode block: under left side cover, above regulator.
    Neutral switch: in a hole in the bottom of the crankcase, just "outside" of the oil pan, on the bottom of the engine, up inside a recessed "well".
    Thermo unit: screws into the thermostat housing.
    Thermoswitch: screws into the thermostat housing.
    The side stand relay has a set of normally closed contacts. When the contacts are closed the TCI is disabled and will not fire the coils. You can simply unplug the side stand relay momentarily to rule out problems with the side stand safety circuit. Note Len's reference of the blue dot that should be on the relay in case you have accidentally installed the incorrect relay.
  12. Turbobob23
    Turbobob23 Member
    Woooooo!!! I got it!! That relay was indeed the problem! I took the one off my XJ1100 to see if they were the same (my great luck they are). Plugged it in and bingo , fire!!
    I'm beyond excited for my son right now. The video posted earlier made me realize I hadn't checked the relay.
    Thanks for posting all your suggestions folks. You've all been a tremendous help with my 1100 and my sons 700. Very appreciative.
    Once we get it final assembled now, I'll post up some pics.
    Thanks again!! Bob
    k-moe and Jetfixer like this.
  13. hogfiddles
    Yaaaay!!!
  14. MiGhost
  15. chacal
    I guess it should also be pointed out that all these items are combined into one big "black box" unit and is no longer a small "cube" type relay........only on the XJ700 and XJ750-X models.
  16. Turbobob23
    Turbobob23 Member
    Yes, my eye was on that as well. But I lucked out with finding the small plastic relay. I gave him mine from my 1100 to get him running. Thanks.
  17. Turbobob23
    Turbobob23 Member
    Well , it runs ,but! Now there's a high idle problem. Like I mean 4-5000 rpm high. Starts off normal but then suddenly revs for no reason. Flicking the throttle makes no difference. Have the carbs off now inspecting them.....any thoughts?
    Bob
  18. MiGhost
    Throttle shaft seals?
    Float levels wet set?
    Running Sync?
    Color tune?
    ~Ghost
  19. Turbobob23
    Turbobob23 Member
    Color tune?...
  20. MiGhost
    One of the last steps in the final tuning process. It involves using a see through spark plug to adjust the fuel mixtures to the correct burn color.
    Make sure your floats are set correctly, and the carbs have a running sync done first.
    ~Ghost
  21. Turbobob23
    Turbobob23 Member
    Aahok. I have the carbs apart , and they're quite gunked up and corroded too. Have to do a major clean before anything else can be done.
    Needless to say since the float shaft is seized , they won't float thus the high idle problem.
    Thanks for all the help. This should be the last of the problems as far as I can tell. We'll do tjetuning afterwards.
    Bob
  22. Turbobob23
    Turbobob23 Member
    Well , I promised a picture my sons XJ700 when it was good to go. So here it is in restored condition in a Nissan color ,deep purple. Almost looks black except when the sun hits it. So much red and purple pearl in it. Frame is black then dusted with one coat purple pearl and cleared. He's 18 now did all but the paint himself which I did. He prepped with body work though , I only sprayed color. Very proud of his hard , and good work.
    Thanks again everybody. Bob
  23. lush90
    lush90 Member
    Outside of Seattle
    Wow, beautiful bike. You guys did a great job, something to remember!
