Engine break in after rebuild
Discussion in 'XJ Technical Chat' started by Desinger_Mike, Mar 31, 2010.
  1. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    My engine is back together and it actually runs!!!
    I did a complete tear down to swap cases after a PO hydrolocked it and blew a rod out the front.
    I honed the cylinders and ended up using "experienced" rings that were very close to the new spec.
    I decided to do some research about break-in process since everyone seems to have a different opinion.
    I found a couple great articles that explain the process and what is happening for those of you interested.
    http://www.ntnoa.org/enginebreakin.htm
    http://www.ktm950.info/how/breakin/engine_breakin.html
    I put three runs in this afternoon and can't get the smile off my face. I can't wait until the process is done and I can see what it will really do.
    It's also very nice to hear the "sewing machine" tapping of my well adjusted valves.
  2. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    If "experienced" rings means used, I dont think you need to worry about "breaking it in" You may not get the results you would as if you installed new rings.
  3. Desinger_Mike
    That is true, the rings do not have the tapered edge, but the cylinder honing still needs to be smoothed off and set it to match the rings.
    Before I started the process, my compression was at 140-143 psi and for the first 20 miles she was a smoker.
    After about 100 miles of break in effort and an oil change (which had a lot of metal shavings) I'm getting nice compression readings.
    160/157/154/158
    By the end of the weekend I hope to be able to really see how she will do.
