Engine mounting bolt...$¥$€$¥$€
Discussion in 'XJ Technical Chat' started by Rags110-2007, Jun 3, 2014.
  1. Rags110-2007
    Rags110-2007 New Member
    United kingdom
    Major help needed....can anyone tell me how you get the rear engine mounting bolt out of the engine mounts..???? I'm rebuilding my 550 maxim and am in the process of stripping it down to the bare frame and this bolt is a nightmare...when I try to undo it it's turning and not coming out yet when I try to tighten it it just turns and doesn't get tight....!!! I'm stumped as what the heck is goin on,,,,,!!€$¥ so any ideas would be gratefully received.... 8O
  2. Wirehairs
    Wirehairs Member
    St. Paul, MN
  3. Rags110-2007
    United kingdom
    Hellooo that's the one,there wasn't a nut on it..!!! And the bolt doesn't come out the other side the thread sits flush with the frame.... Doing my head in reckon I'm gonna end up cutting it in half coz I'm slowly loosin patience....,,,!? ,,
    Is the weight off of the bolt? Once the nut is off (seems like yours has been missing for a while). Then the bolt should be able to be pushed out. Turning it won't do anything because ther are no threads for it to engage other than those on the missing nut.
    That rear bolt is the main connection between the engine and the frame, so don't pull it out until the engine is fully supported by something other than the frame.
  5. Rags110-2007
    United kingdom
    Will ave another bash at it tomoz thanks for the advice...,,!!
  6. Rags110-2007
    United kingdom
    update on pain in the arse bolt.....eventually got it out looks as tho its had the nut sheared off on one end and it was rusted to the inside of the sleeve...!!!! patience is a virtue....!! cheers for now
  7. k-moe
    Excellent news. Upon reassembly be sure to coat the shoulder of that bolt with grease, and use loctite on the threads so the nut doesn't corrode to the threads.
