engine rebuild
Discussion in 'XJ Modifications' started by Jburton, Jan 13, 2018.
  1. Jburton
    Jburton New Member
    Wisconsin
    I have an 81 xj750 seca and ecently I pulled the motor an I am looking to rebuild it. wondering if anyone knows of any aftermarket parts such as forged pistons, aluminum rods, anything of that sort that are available.
    is there a reason you are rebuilding the motor or you just want to?
  3. Jburton
    Jburton New Member
    Wisconsin
    I found metal shavings in the oil. im rebuilding it because i want to find this problem as well as i just want to instead of buying another used motor. its only a 15,000 mile engine
  4. Simmy
    That’s barely broken in. A new motor will always shed metal as the parts mesh together. You wouldn’t have believed what I found in my current KLR’s 1st oil change. There was a 3” diameter shaving from machining the oil filter housing missed by their QC.
    Also may KTM ate it’s electric start gears and I was pulling complete gear teeth from the drain plug. This bike has 4 oil filters/screens so it’s still running solid after fixing that.
    Having said this you can use XJ900 components with some custom machining, something I’m working on myself.
  5. Jburton
    Jburton New Member
    Wisconsin
    well. i have it out and off id still like to dive in and rebuild it. just wondering about aftermarket performance parts. thanks for the heads up on the metal shavings though
  6. Simmy
    The aftermarket performance parts manufacturer’s direct their attention to the new bikes being raced as this crowd will spend big for any advantage. Is some cases older bikes being raced. It’s just not good business stocking big bore and performance cam kits they’d need to list for more than the value of a 750 Seca. You might be ready to spend large but not enough others are, not enough to support this.
  7. Jburton
    Jburton New Member
    Wisconsin
    hmm, ok. thanks. ill keep my eyes out but until then itl be a stock rebuild i guess!!
  8. hogfiddles
    There was a big bore kit available for the 750… Not easy to find though
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
  10. hogfiddles
    Looks like it
  11. chacal
    Both of those kits use a 68.00mm bore......3.00mm over the stock size. I've never understood how they will work well with the stock cylinder liners, the max. O/S that Yamaha recommends is +1.00mm. Although there is enough meat in the cylinder liners to actually bore them out that large, those walls be getting awfully thin at that point, and I'd be a little concerned about long-term reliability of such a set-up. For racing purposes, doing things like that is okay/common, but so is doing periodic full engine rebuilds.........up to and including replacing cylinder liners!
    But, like they say, there is no substitute for extra cubic inches in the horsepower game.....
  12. Jburton
    Jburton New Member
    Wisconsin
    to be honest i probably will not do a big bore kit for that exact reason. i am planning to use this bike as almost a daily driver and dont want to risk blowing through a wall.
  13. Simmy
    Hey thanks for posting that Matti, I may need that later for my project. Haven’t seen inside my 900 motor yet.
  14. Polock
    isn't there something about a 900 cam fitting a 750 ?
  15. k-moe
    The ultimate result is going to be spending money that doesn't need to be spent.
    The most reasonable courses of action are:
    1: put the engine back in and tend to all of the other things that actually need to be done at this point in the machine's life.
    2: Split the cases to replace the alternator chain guide before it grenades, and rebuild the starter clutch while you're in there. Then put the engine back in and move on to option one.
  16. k-moe
    That's a maybe. I don't recall that anyone has done that and reported about the results here.
  17. k-moe
    I know that at least one of the kits (not sure if it's one that is curently available) requires boring out the case to accept larger diameter liners.
  18. Jburton
    Jburton New Member
    Wisconsin
    well, i just got in after getting tearing into and off the top end, turns out the metal shavings was a blown connecting rod. now im really stuck, can this still be repaired??? what are the steps that need to be taken. thanks for any help
  19. chacal
    Explain further please............spun bearing, snapped rod, spit off the cap?
  20. Jburton
    Jburton New Member
    Wisconsin
    one bolt blew off the cap and came off, busted part of the skirt off. the upper and lower case look scuffed but not punctured as far as i can see. these are the best pictures i could get as of now. I will be splitting the case tomorrow with more pictures
