Exhaust gasket question
Discussion in 'XJ Technical Chat' started by Robert24b, May 19, 2023.
  1. Robert24b
    Robert24b New Member
    Colorado
    Pulled apart my exhaust and it seems I need new gaskets.
    Without knowing exactly what to search for, I'm reduced to using "exhaust gasket" as a search. Are there technical/special names for all of the gaskets on the exhaust?
    I'm assuming I need x4 upper "crush gaskets",
    X4 lower ones (what are they called?)
    Finally, x2 for the exhaust pipes.
    This is for my 82' xj650r seca
    Thanks!
  2. Fuller56
    Fuller56 Well-Known Member
    at the upper right of each page of this forum is the XJ4EVER logo. Click on that and it will take you to Len Chacal's page of XJ parts and info and advice. There is a really good description of pretty much all XJ parts, where they go and what they fit. Once you determine what parts you need/want start a conversation with "Chacal" and he will get back to you quickly. He is the best guy to do business with you will likely ever run across. His pages will explain what parts you need for your exhaust.
    Good Luck!
    John
