Exhaust Manifold Gaskets
Discussion in 'XJ Technical Chat' started by fiveofakind, Jun 14, 2010.
  1. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    1982 XJ750j Maxim
    This there suppose exhaust gasket for the pipes...it seems to me my stock pipes bolt direct to the cylinder head with their holders & it appears that no gasket O-Ring is needed.....
    Doesn't appear that there is any room for them....
    I have seen sites where they sell them
    Am I correct that they are neccessary...
    Thanks in advance....
    5ofakind
  2. gitbox
    gitbox Member
    Yes, it uses gaskets. Copper colored rings. Sometimes they get so nasty they look like part of the head.
  3. bigfitz52
    Agreed, on both points. They usually get "pounded" into the head and you don't even realize they're there. Use something with a small sharp point and "pick" them out.
  4. yamaman
    yamaman Member
    Staten Island, NY
    I'm about to drop my complete exhaust to change the Oil Level Sensor Oring. Do you guys think the copper head gaskets should be replaced?
  5. fiveofakind
    San Diego, CA
    I didnt see any when I dropped my exhaust on my '82 XJ750J......I looked real hard to find them......they are not there......
    5ofakind
  6. Vedalkin
    Vedalkin Member
    Just did mine. They are actually weird. Like some kind of high temp wrap inside a pressed ring, not solid metal like I had thought. The old ones were so hard to distinguish from the engine ports, it wasn't until I took a small screwdriver to them I was able to pry them out.
    These are the ones I replaced them with.(If you enlarge the image you can kinda make out the inner "wrapping" I'm talking about)
    http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0226471077
    I put em in, then put a couple hundred miles on it, then re-tightened and they seem to be working well. No leaks.
  7. bigfitz52
    I would. That's the last place you want an exhaust leak.
  8. Erman
    Erman Member
    Oslo, Norway
    Can I just ask a quick question here? I noticed yesterday that there is a little bit of white (very pale) smoke coming from cylinder 1 exhaust manifold.
    1 - can it still be ridden until I get new washers?
    2 - is it normal / dangerous or what?
  9. bigfitz52
    Where the pipe/collar meets the head?
    1- I wouldn't.
    2- Not normal (unless a trace of oil dribbled in there and was burning off)/probably not dangerous but certainly worth investigating further.
    You might want to just check the snugness of the collar nuts. Be careful, they're not supposed to be super tight and the exhaust studs tend to be brittle.
  10. fiveofakind
    San Diego, CA
    I looked again & my original exhaust manifold gaskets are there....I had to look real hard & scrape a little bit to actually see them......
    Now my question is how do you get them out......pry them out ??? Tried that but they are being stubborn... I dont want to damage the the walls of the exhaust ports......
    Any suggestions ???
  11. chuckles_no
    chuckles_no Member
    wisconsin
    They will come loose very easily. Don't be scared. Haha. Just work them out with some needlenose or a flathead. They'll come out. If they are really jammed and baked on in there, it might take some extra scraping, but thats it. Oh and it'll be kinda hard to damage the ports unless you are using a hammer and chisle or something insane like that. You'll be fine.
  12. parts
    parts Member
    prescott valley az
    Use your favorite lube goop to help them slip out.
    Then be sure to clean the surfaces with carb or brake
    cleaner so the new gaskets have a nice smooth and clean
    surface to seal with.
    The closer to brand new you can make any surface that needs
    sealing the less chance of having to take it apart again because
    of some little bit of crap causing a leak.
  13. bigfitz52
    They're soft. An awl with a sharp point, a small flat screwdriver, I use a 'springhook' from my adding machine repair days. You won't dig into the head, you should be able to dig right into the old gasket. Once you get them broken loose they pop right out.
  14. yamaman
    yamaman Member
    Staten Island, NY
    mine were actually still a little soft, so I kept them in there. My new ones are on standby if needed/for sale
  15. Erman
    Erman Member
    Oslo, Norway
    You know, when I finally find the ones on mine, they were of a kind that was papery on the inside with a thin layer of aluminium closing around it - like a "C".
    Also, they were so baked that I didn't notice them before actually prying blindly with a flathead :p
    They're replaced with a copper ring type from Wemoto now.
