Exhaust Mod advice please
Discussion in 'XJ Modifications' started by Carvall, Apr 29, 2011.
  1. Carvall
    Carvall Member
    Seattle
  2. BillB
    BillB Active Member
    Tulsa Oklahoma
    You might be looking at some cutting and welding. Thats not a huge deal.
  3. Carvall
    Carvall Member
    Seattle
    I'm afraid that the with the supertrapp ?
  4. Carvall
    Carvall Member
    Seattle
    Sorry I mixed my toughts. You mean with the supertrapps?
  5. BillB
    BillB Active Member
    Tulsa Oklahoma
    either one
  6. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Your going to need some measurements to see if either of those will leave room for the center stand should you want to continue using it.
    The headers and collector box also bolt under the engine to help support it, so you may want to keep that in mind when going with another system to find an alternative way to support it.
  7. bigfitz52
    The other exhaust system came off a Moto Guzzi 750 twin.
    While anything can be made to fit, I don't see either of those as a "bolt-up" option.
    Depends on how much re-engineering and modifying you want to get into.
  8. Carvall
    Carvall Member
    Seattle
    That's true. I guess I'm more worried about if I need to re jet the carbs or just a tune up would do it. I feel like the breva exhaust would be a better fit in that aspect but Im kind of inclined to buy the supertrapp because the sound and more flexibility to adjust. But the truth is that I'm just espacultiang and that is why I need the advice.
    Do you have any experience whith supertrapp exhaust?
    Thanks for your input.
  9. loudjosh81
    loudjosh81 Member
    Pontiac, Mi
    I put a supertrapp on my baby bandit (250cc) and it was great. I didn't have to change anything with the carbs/airbox set up. I was able to adjust the plates on the end with minimal effort, and after a few rides, I had it tuned in perfectly. The only negative drawback I can think of is the noise. That bike was loud. People covered ears, jumped out of the way when I was going through town, ran away, it kept me entertained.
    I am actually thinking of the supertrapp route for the seca750. As long as I dont have to mess with carbs/airbox again, i'd be happy for that noise in my life once again.
  10. Carvall
    Carvall Member
    Seattle
    LOL I will let you know what I get!
  11. Zookie400
    Zookie400 Active Member
    Connecticut
    a tune up is not going to fix jetting issues.
    if you change any part of the intake or exhaust, you will need to rejet, especially if it still has stock jetting from the 80's.
    the supertrapp can have discs removed or added and you might be able to tune the muffler to the carbs current jetting close enough to only require a little tweaking with the pilot screw or a shim of the needle.
  12. Carvall
    Carvall Member
    Seattle
    I went to check the supertrapp Shorties and they were to short. The guzzi exhaust are nice but a little expensive. Then I saw thisones on Ebay. I think I will get them. They are even angled already!
  13. Carvall
    Carvall Member
    Seattle
    OK I got this suppertrapp. Im excited to see the performance improvement with these mufflers.
  14. Polock
    i use 6 plates on a mac 4/1 with 128 mains and 41 pilots, things happen fast after 6K
  15. Carvall
    Carvall Member
    Seattle
    What sizes are the stock main and pilot?
  16. Polock
    120 main and 40 pilot
  17. Carvall
    Carvall Member
    Seattle
    Well, Supertrapps have been installed. Cleaned my carbs and sincronized. I am susing only 5 plates with stock jets. Runs smooth smooth!!! I will change the jets because I have almost 4 turns out and the plugs are barely tan.
    I do like the sound but not much diffrence from the stock exhaust. I do feel more power though but the main benefit is the smoothness when im on the highway. Almost no vibration.
  18. Carvall
    Carvall Member
    Seattle
  19. bigfitz52
    It's probably more a result of the carbs being sync'ed than the pipes, honest.
  20. TIMEtoRIDE
    I need pics - of Stainless supertrapps, correctly bent?? Installed !! Oooh - Jealous !
  21. Carvall
    Carvall Member
    Seattle
    BigFitz. I think is a combination of both. May be more the sync than the exhaust but definetly the exhaust helped because before syncronized I went for a ride and I felt improvement.
    TIMEtoRIDE they were already bent. I was lucky to find them already like that. Even the bracket wass in the right position. They were almost true slip ons. I will post pics as soon as I clean the new beast unleashed!!
