Exhaust pipes to engine discolored - "leaking"
Discussion in 'XJ Technical Chat' started by Alain, May 17, 2016.
  1. Alain
    Alain Member
    See the picture here for my exhaust pipes coming out of the engine. Does this imply that one of my exhaust pipes is not 'sealed' properly - like I should re-seat it?
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    New exhaust crush gaskets is part of the re-commission process. That's a single walled aftermarket system which will color. The stock headers are double walled. The leaking valve cover gasket and/or the washers that hold the cover down should also be inspected/replaced.
    Gary H.
    Toomanybikes likes this.
  3. k-moe
    And they are rusty.
  4. Alain
    Alain Member
    Wait, when you say "crush gaskets", do you mean part 11 or 12 in the picture attached here.
  5. tcoop
    tcoop Active Member
    South Weber, Utah
    Part 11 in the picture
  6. Jetfixer
    Soak nuts in penetrant oil carefully try to lossen nuts ,unbolt mufflers and remove header ....use a wire wheel in a drill knock off rust... spray paint with Hi Temp Barbecue black paint ...reinstall with new gaskets ...
  7. XJ550H
    sometimes with mac exhaust(aftermarket exhaust) you have to double up on gaskets, you may also want to put a flat washer and split washer under the nut to keep it tight.
    tighten all nuts slowly and evenly across the exhaust pipes not fully one at a time . use proper torque also.
  8. k-moe
    You can also just use two standard nuts as jam-nuts if you don't care about the original look.
    XJ550H likes this.
  9. Alain
    Alain Member
    i installed 1x gasket on each exhaust (rather than double up) yesterday but unsure of the orientation of the gasket. the gasket seems directional as the internal diameter is rounded on one side and squared on the other. I installed the gasket with rounded edge to the exhaust - with flat side facing the engine.
    I swear it's leaking exhaust.
    PS - when I removed it, I only saw 1x gasket on each exhaust on the original configuration.
    Here's a link to the pic: http://www.kfm-motorraeder.de/cms/en/genuine-spare-parts/yamaha-spare-parts?itemid=4BR146130000
  10. Alain
    Alain Member
    Thanks for the advice. This is my after pic: Changed head gasket and also exhaust gaskets. If you look at what I circled there, I still get leaks with the new gasket. Is it that 'half moon shaped' thing? I forgot to check if this was a piece of rubber that could be replaced on the engine block... I can't seem to find it in the parts pictures.
  11. XJ550H
  12. jayrodoh
    jayrodoh YimYam
    Cleveland
    I think you mean valve cover gasket. The head gasket requires removing the head. The rubber plug is a valve cover gasket rubber cam-end plug and they are sold separately from the valve cover gasket.
  13. jayrodoh
    jayrodoh YimYam
    Cleveland
    On the 650 non yics they are separate.
  14. DrewUth
    DrewUth Active Member
    South Jersey
    Clean it with some carb or brake cleaner, and if you are careful and neat you can apply some Ultra-grey or Black RTV with a q-tip or something to seal around the edges without having to take the valve cover back off and it wont look bad.
  15. Mustang
    Mustang Member
    Masonville
    I'm having my exaust painted with ceramic paint ant thoughts on thi?s
  16. k-moe
    Do it.
  17. Alain
    Alain Member
    Wait, I just installed a new gasket on the head cover. If I remove it carefully w/o tearing the gasket, can I re-use it when I put in new 'half moon' plugs?
  18. Alain
    Alain Member
  19. Alain
    Alain Member
    You know it's funny I have a lot of this RED RTV stuff lying around when I helicoiled my spark plugs (https://www.amazon.ca/Permatex-81160-High-Temp-Silicone-Gasket/dp/B0002UEN1A)
  20. XJ550H
    yes you can reuse it
    you are only supposed to "glue" the gasket to the valve cover not the cylinder head.
    does it require you to bake it on ?
    down side it the spec
    • Temperature range of -65F to 650F intermittent
    the black high temp rtv does not use the word intermittent
  21. DrewUth
    South Jersey
    Ew don't use the red or copper stuff, that looks hacked up and sh*tty. My suggestion was to use the grey or black SPARINGLY to seal the weep without having to disassemble things. If care is taken, it can be done neatly and no one would know, and it saves you time and $$.
    Lightcs1776 likes this.
  22. XJ550H
    carefully pull the valve cover . and fix it right, rtv the half moons or replace them and rtv in place I would replace them , that way you will not have to go into the cover for 5000 miles when you recheck the valve shim.
    sorry to say you may have to replace the VC gasket if you damage it but sometimes the learning curve cost some extra money.
    if you want to wait untill you recheck valve shims just clean and smear moons with rtv as suggested. short term fix.
  23. Alain
    Alain Member
    Fack.... you are right. I still have to open it up and put RTV in between. Might as well do it right with new parts.
  24. k-moe
    The pre-YICS valve cover gaskets are paper. Rarely does one come off clean enough to reuse.
  25. Alain
    Alain Member
    I still think it's leaking because I can smell exhaust. I'm tempted to tighten it past the torque setting of 0.8kgf as per the Haynes manual. It's lisTed as "exhaust flange nut".
    Does anyone have another torque settings I can use?
  26. jayrodoh
    jayrodoh YimYam
    Cleveland
    Don't overtighten! Broken studs suck.
    If it's leaking with the factory spec then something else is wrong. Pipes may not be aligning properly etc.
  27. XJ550H
    1 m-kg or 7.2 ft lb M6x1.0 nut this is the xj 550 spec same nut as 650
    consider that the seal you took out was almost flat compared to a new seal it will take a few retorques to fully seat them
    and you are using after market exhaust with welded flange not a floating nut ring
    with the disadvantage of not being able to aline the pipe to the head, try to center the flange on the bolts
    Alain likes this.
  28. k-moe
    Loosen up all of the mounting hardware. Tighten the flanges first, then the rest working toward the back.
    Alain likes this.
