exhaust questions!!!!!!
Discussion in 'XJ Modifications' started by sega_saturn, May 7, 2012.
  1. sega_saturn
    sega_saturn New Member
    North Dakota
    so... my stock exhaust has about a thousand holes in the muffler secton, and everything inside of the left muffler isnt attached to anything.. im assuming its whats causing popping after i close the throttle because running rich seems like it doesnt change anything. the pipes leading to the muffler are fine though. ive obtained mufflers from a friend from a yamaha 1100 bike (model# 5YS1)... how much modification do you think ill have to go through to get these properly working on my xj650?
  2. bigfitz52
    Some cutting, probably a sleeve/adapter situation; I suspect the 1100 pipes will be a tad bigger in diameter than those on the 650.
    On both bikes, the original pipes were welded to the collector/one headpipe, so making it into a "bolt-up" will require a bit of doing.
    If you're lucky, you can leave enough of a "stub" on the original exhaust for it to fit inside the (assumed to be) bigger mufflers off the 1100. If it turns out they're the same or close to the same, then some fabrication and ingenuity may be required.
  3. sega_saturn
    North Dakota
    so youre saying all i really have to do is cosmetic modifying to get them to work properly? i wont have to re-jet or re-tune the engine any further?!
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Are you just looking for a left muffler? Or are your head pipes bad also?
  5. sega_saturn
    North Dakota
    the head pipes are fine... both of the stock mufflers are in really rough shape.. these ones from the 1100 are basically brand new!
    but basically... if i slice these up and put them on... they should work just fine?? or am i going to have to re-tune everything?
  6. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Should be fine as long as the stock baffles are intact on the ones you put on, and are not just staright through.
  7. MN-Maxims
    Saint Paul, MN
    Ill trade a pretty nice 650 LH muff for the pair of those 1100 muffs
