EXHAUST SYSTEMS
Discussion in 'Hangout Lounge' started by neilxjr, Sep 22, 2010.
  1. neilxjr
    neilxjr New Member
    Pulborough, West Sussex . UK.
    Hi, could anyone help , doing some work on my FJ600 1985 ( same as XJ600 ) USA spec, it needs a new exhaust system, I want to fit a 4 in 1 system, does any one know if a XJ550 4 in 1 would fit the FJ/xj600 series , as far as I know they are pretty much the same layout etc .
    Many thanks,
    Neil.
  2. zombiehouse
    zombiehouse Member
    Pomona, Ca
    I used to run an FZ600 exhaust on my 550 Seca. If the FZ600 and FJ600 exhausts are interchangeable then the 550 Seca exhaust should fit your bike.
  3. zombiehouse
    zombiehouse Member
    Pomona, Ca
    The 550 Seca exhaust rear mounting point is a lot closer to the engine than on the 600 though. You would probably have to fab up a rear mount.
  4. matie69
    matie69 Member
    Norfolk
    A better bet might be the fz600, that is the same engine as xj/fj and might just need slight adjustments to mounting.Looking on ebay plentiful available.
    I have a motad neta 4-1 fitted to my xj at present. Can be quite pricey as new.
