Exhaust
Discussion in 'XJ Technical Chat' started by Nic, Dec 5, 2016.
  1. Nic
    Nic Member
    Philadelphia
    What kind of exhaust can I put on my xj650j with no problems
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    An exhaust for a xj650j. :D:D
  3. Jetfixer
    Mac makes a 4 into 2 as well as 4 into one... are not cheap but work ok ..I have the Mac 4 into 2 on my XJ750 Seca.
  4. hogfiddles
    ...or xj650G, Xj650H, xj650K, xj650MK,.........
    Xjrider92117 likes this.
  5. Nic
    Nic Member
    Philadelphia
    Do you have any suggestions i was reading up on it, it doesn't seem like I can put any exhaust system on the xj650j without modification of the carbs. The original exhaust is rusted at the collector.
  6. Nic
    Nic Member
    Philadelphia
    Come on guy this bike is growing on me.
  7. hogfiddles
    Those ARE the suggestions. You have a 650 maxim. ANY 650 Maxim from 1980-1984 will interchange.
    Yes, I said 1984. No, it is not a typo-- the 650 Maxim was available in 1984 outside of the USA.
    The 650 Maxim did not have a collector box Per-say..... The left two pipes were connected to a 2/1 receiver that was part of a single muffler/receiver. Same for the right side. There was a cross-over pipe with a slip joint as part of each side, that joined under the engine.
    Now, if you actually HAVE a collector box, then you actually have a 650Rj.... THAT collector IS unique to the 650rj.....
  8. Nic
    Nic Member
    Philadelphia
  9. hogfiddles
    Time for show-n-tell:
    Xj650rj
    Xj650g/h/j/k
    Hope that helps clarify things.......
  10. Nic
    Nic Member
    Philadelphia
    Yes want to sell me the one I need hogfiddles the j model with the silencer not collector.
  11. hogfiddles
    I will look to see if I have anything available
  12. Nic
    Nic Member
    Philadelphia
  13. xjyamaha
    xjyamaha Member
    Omaha, NE
    Have a Mac 4 into 2 on my XJ650j. Works well and looks good.
  14. Nic
    Nic Member
    Philadelphia
    Did you have to do anything to the carbs
  15. xjyamaha
    xjyamaha Member
    Omaha, NE
    I didn't, and my bike runs fine. I've seen a recommendation to go up a size in jets, but I just went ahead with the factory sizes.
  16. hogfiddles
    All I have is some beat up stuff, nothing good enough to sell yet
  17. Xjrider92117
    San Jose Ca
