experince the xj-forks/brakes
Discussion in 'XJ Technical Chat' started by ridz, Apr 20, 2007.
  1. ridz
    ridz Member
    Ride hard and live free!
    my biggest thing when I starting to wrench on my cycle was...Taking some of the mystery out of it..So im posting these pics in hopes that it will serve to help others just starting out .....goodluuck and good day...
    Ridz safe....Ridz 8)
  2. ridz
    ridz Member
    If I can get these pics on It will show a clog in one of the orfices on the brake caliper..This is what caused my front end woble along with froze pistons..I belive anywayz. Let me explain further. It will show one clean then one clogged.. :wink:
  3. Robert
    Excellent documentation Ridz, I'm glad your thinking of others. Keep it up.
  4. RickCoMatic
    That thin-walled, rusty, piece of tubing ... above the long, Fork Spring and below the End Cap is the Factory Pre-load.
    Measure the length of that Pre-Load. Fabricate a more sturdy Pre-Load using solid dowel, solid plastic rod (shower / closet rod) or PVC Pipe.
    To Performance tune your Front End for an slight increase in stability for those occasions when the guy next to you wants to see who can get to the next light first ... add 2.0 - to - 2.5 cm of additional Pre-load over the Factory set-up.
    You'll like the additional stability in the turns ... and you won't KNEEL as much when you get on the front brakes.
    Your building a bike bro ...
    Keep us advised like you are doing.
    Nice work; ridz ...
    We got your back.
  5. MAX-X
    MAX-X Member
    Ohio
    Hey Ridz, Are you replacing your springs as well? When I did mine I installed some Progressive springs, a lot better now.
  6. ridz
    ridz Member
    no I think I might do a little budgeting in that area. Rick has aroused my suspicions on the preload technique. my spring still has a good measurement reading on it..not like im going to enjoy trying to jam them down and safely stick the aluminum threaded caps on it by even 2.5cm more. so thats it . ridz safe. ridz 8)
  7. Danilo
    Danilo Member
    Vancouver canada
    IF.. you want to increase the spring rate .. Distinctly.. different from increasing the Preload.Just saw a couple or more winds off yr existing springs.
    Yup Poor man's "new and Improved ..performance' springs :)
    You will need to increase the spacer tube lengththough Instructions above are good.. but yoou won't have to fight to tryand squeeze the spring into submission. Remember to err on the side of Caution Better to cut the spring twice than take too much off in eagerness. G'luck.
  8. Alive
    Alive Active Member
    Queensland, Australia
    Just got the first fork back together and when I compress it by hand I get a squeaking spring sound. Is this normal Or do I need to open em back up again?
    Cheers
  9. Robert
    I don't recall hearing any spring squeek in my tubes. Got the oil in there yet?
  10. RickCoMatic
    The Factory Book wants the Spring placed to that the GREATER Pitches in the Spring are at the BOTTOM.
    (Here comes some more lively discussion)
  11. Alive
    Alive Active Member
    Yup 300mls of 15w fork oil
  12. Alive
    Alive Active Member
    One of the pieces of paper I got with the progressive springs says that it does not matter which way around you put them :)
