Extra TCI uniits
Discussion in 'For Sale, Trade/Swap, Wanted' started by permissiontolandfmx, Oct 8, 2012.
  1. permissiontolandfmx
    permissiontolandfmx Member
    Edmonton, Alberta Canada
    I have 4 Tested tci units that I wil part with if someone needs one.
  2. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    Post up the models that they are from and the part numbers printed on them. You'll likely get more responses that way.
    TCI units are different between the different models in terms of spark advance, which I'm pretty sure is a function of displacement, and also might be different between maxims and secas.
  3. bigfitz52
    It is for some Secas and Maxims anyway.
  4. permissiontolandfmx
    Ill try to get around to it tomorrow and post some pictures.
  5. permissiontolandfmx
    Little unsure of the model these match up with the red ones "5G2-10" are labeled for '82 XJ750's.....The yellow are actually red TCI unit's just faded from the sun. The side covers were missing.
    The 4H7-10 has writing on it that says 650 but in the manual in a picture under the 750 electrical section it has this tci type in the illustration...which doesn't really mean anything..
    They all work but in need of an XJ wizard to clarify which is for what!
  6. permissiontolandfmx
    where is a wizard when you want one??
  7. Bushy
    Bushy Active Member
    I 'think' the first one -4H7 is for a 650, all the rest -5G2 are for 750, same as mine.
  8. permissiontolandfmx
    That's my assumption too. Taking offers and I'll ship anywhere for $10 flat rate. Individual or the lot.
  9. adrian1
    adrian1 Active Member
  10. MiGhost
    MiGhost Well-Known Member
    Doing a part number comparison. This is what I have come up with.
    Non-YICS
    The 4H7 was originally used on the 80-81 non-YICS 650, and then replaced by the 5V2.
    YICS
    The 5G2 was used for all the 82-83 650/750 YICS
    Ghost
  11. adrian1
    curious......I wonder what it was that made them change the units?
  12. MiGhost
    My guess would be a timing advance change in the YICS engines.
    Ghost
  13. CapnRedbeard
    CapnRedbeard Member
    London England
    Thinking of puchasing a spare tci 5G2 as a back up. Can u PM me with an idea of the approx price your looking for. That and standard mail to UK
  14. raptor8
    raptor8 Member
    Bend OR
    I THINK, though I'm not positive, that the 4 stands for 4 wires in the connector, the 5 for 5 wires. I believe the 5th wire is the kickstand switch, which started in 82. Yes, I have a 4H7 in my 81 xj650.
    I changed mine last year to solve a tip-in stumble, which it did solve.
  15. CapnRedbeard
    CapnRedbeard Member
    London England
    Permissionto land, Thanks unit arrived in UK earlier this week. Only down side is UK customs slapped an import tax on it! Currently arguing with them but had to pay to get it released.
    At least I now have a spare TCI unit which should keep my bike going if my original fails!
    many thanks
    CapnRedbeard
  16. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    I've had that problem with the bastards, so what i do now is to get the seller to write on the export form as a gift and to make out the price as low as possible.
    The last item i bought from USA was an XJ1100 TCI unit which cost me £130 plus the p&p. I asked the seller if he could do something about the export form and he said yes.
    It came as a $10 gift with the postage more than the make believe price but at least the Customs and Excise were non the wiser.
    I've been stung on carbs imported and allsorts. Bastards. It's secondhand and already had VAT paid and those fookers still want more.
  17. quebecois59
    I'm a little bit confused as for what would be the correct TCI for an '83 Maxim 750cc...can anyone tell me for sure, because it doesn't run properly and I wonder if it could be the problem (or one of the problems)?
  18. CapnRedbeard
    CapnRedbeard Member
    London England
    fj111200, Next time I will ensure that cost price is below tax threshold £15.00 GBP.
    And as you say 2nd hand, 30 odd year old is and still accruing import tax is a joke. Rip off Britain!
  19. CapnRedbeard
    CapnRedbeard Member
    London England
    Quebecois59, Not exactly sure for definite, but I'm sure the gurus will confirm. prety sure that your looking for the same TCI unit as being offered by permissiontoland.
    Has your tci not got the reference numbers/ data plate attached?
  20. quebecois59
    I don't have it next to me, neither even close to my place (bike is stored 40 minutes from home).
  21. FJ111200
    A 5G2 - 10 would be the right TCI unit for your bike.
  22. quebecois59
    OK I gave myself a kick in the butt (sometimes I'm lazy on saturday mornings)and had a look at the parts diagram. It seems that the proper TCI unit for my '83 Maxim 750 is the 5G2.
    Actually, the 5G2 unit is shared by the following models and years:
    '82-84 Maxim 650
    '81 to '83 Seca 750
    '82-83 Maxim 750
    As for the 4H7 TCI unit, it is shared by these:
    '80-81 Maxim 650
    '82 Seca 650
    They also list a 5V2 TCI unit for these last models and years, don't know why.
    Hope this would help.
  23. chacal
    HCP12647
    OEM TCI Ignitor Unit
    oem # unknown
    small red label lettered:
    TYPE TID12-07
    10R-10 (date code)
    Advance curve: unknown
    Application:
    1982 XS400
    HCP412
    oem # 4U8-82305-10-00
    small blue label lettered:
    TID14-05
    4U8-10 (date code)
    4 + 5 terminals
    Advance curve:
    5* at 1,250 rpms
    7* at 1850 rpm +/- 200 rpms
    36* at 3300 +/- 250 rpms
    38* +/- 2* at 4000+ rpms
    Applications:
    XJ550 all north american models
    HCP413
    oem # 4H7-82305-10-00
    small black label lettered:
    TYPE TID14-02
    4H7-10 (date code)
    4 + 4 terminals
    Advance curve:
    10* at 1050 rpms
    12* at 1800 +/- 200 rpms
    35.5* at 4100 +/- 400 rpms
    37.5* +/- 2* at 5000 rpms
    Applications:
    1980-81 XJ650 Maxim and Midnight Maxim
    HCP7572
    oem # 5V2-82305-10-00
    small green label lettered:
    TYPE TID14-08
    5V2-10 (date code)
    4 + 5 terminals
    Advance curve:
    7* +/- 1* at 1050 rpm
    9* at 1600 +/- 200 rpms
    35.5* at 3300 +/- 300 rpms
    37.5* +/- 2* at 4000+ rpms
    Applications:
    XJ650RJ and RJC Seca
    HCP414
    oem # 5G2-82305-10-00
    TYPE TID14-06
    5G2-10 (date code)
    4 + 5 terminals
    Advance curve:
    (something may be suspect, it's the same curve as the XJ650RJ above??
    XJ750 Seca (factory manual):
    7* at 1050 rpm
    37.5* +/- 2* at 5000+ rpms
    Applications:
    XJ650 Police models
    1982-84 XJ650 Maxim
    1981-83 XJ750 all models
    XJ750 Police models
    HCP415
    oem # 16G-82305-10-00
    larger black label lettered:
    IGNITION UNIT
    TYPE TID14-13
    16G-10 (date code)
    Hitachi, Ltd. Tokyo Japan
    NOTE: different size and orientation case than all others.
    has two harnesses
    Advance curve:
    5* at 1050 rpms
    25* at 2500 rpms (boost pressure 0mm or greater)
    at 0mm Hg:
    5* +/- 1* at 1050 rpms
    25* +/- 2* at 3000 rpms
    26* +/- 2* at 9000 rpms
    at -50mm Hg:
    10* at 1190 +/- 230 rpms
    30* +/- 2.5* at 200 rpms
    33* +/- 2.5* at 3000 rpms
    At 3000 rpms:
    30.5* at -50 to -20 mmHg
    27.5* at -30 to 0 mmHg
    Application:
    XJ650 Turbo
    HCP416
    oem # 1FG-82305-10-00
    small purple label lettered:
    TID14-44
    1FG-10 (date code)
    4 + 5 terminals
    Advance curve:
    7* at 1050 rpms
    ~18* at 2000 rpms
    ~27* at 3000 rpms
    ~33* at 4000 rpms
    37/5* at 5000+ rpms
    Application:
    XJ700 non-X
    HCP417
    oem # 1AA-82305-10-00
    large yellow label lettered:
    IC IGNITOR
    TID14-35
    1AA-10 (date code)
    Advance curve:
    5* +/- 1* at 1100 rpms
    15* to 35* (??) at 2000 rpms
    40.5* to 45* at 3000 rpms
    40* to 45* to 4000 rpms
    39* to 44* at 5000 rpms
    36* to 41* at 8000 rpms
    Application:
    XJ700-X
    HCP14536
    oem #1FL-82305-10-00
    large white label with green lettering lettered:
    IC IGNITOR
    TID14-47
    1FL-10 (date code)
    Advance curve:
    Application:
    XJ750-X
    HCP10489
    oem # 29R-82305-10-00
    TYPE TID14-21
    29R-10 (date code)
    Applications:
    XJ750RL (model 45T)
    XJ750 E-II
    HCP418
    oem # 31A-82305-10-00
    TYPE TID14-19
    31A-10 (date code)
    3 + 6 terminals
    Advance curve:
    7* at 1600 +/- 225 rpms
    30* at 2900 +/- 300 rpms
    33.5* +/- 2* at 3500 rpms
    38.5* +/- 2* at 6000 rpms
    39.5* +/- 2* at 6000 rpms
    40* at 5500 rpms
    36* at 9000 rpms
    Applications:
    XJ900RK, RL
    HCP11857
    oem # 58L-82305-10-00
    small yellow/golden label lettered:
    TYPE TID14-37
    58L-10 (date code)
    Applications:
    XJ900N, FN, F
    HCP419
    oem # 10M-82305-10-00
    small aqua label lettered:
    TYPE TID14-10
    10M-10 (date code)
    uses non-latching connectors
    Application:
    XJ1100
    Others:
    TDI14-33
    XJ 400 Special??
    TID 14-11
    11R-10
    yellowish-gold label
    1982-85 4K0 models
    Franz likes this.
  24. hogfiddles
    Nice. Leave it to Len to give the nitty-gritty.
    I'm printing this one out.....
    Dave
  25. quebecois59
    Excellent wrap-up, indeed.
    I don't understand at all what all of these advance numbers could mean, though. Could it be enough to make a '83 Maxim 750 run very rough if you put a 4H7 unit while a 5G2 is the right one?
    I can't remember exactly which one I put in, only thing I remember is that I was told it would run ok, but it didn't. This said, there are plenty of things that could be wrong except the TCI (compression not tested, valves not set, carbs not balanced), but it would be a good start to put the right TCI in.
  26. k-moe
    The advance is telling you when the spark fires in degrees of crank rotation before TDC. Having the wrong advance curve will definitely affect how well the engine runs as spark advance is dependent on the valve timing of the engine. While it is possible to run with spark timing that is different than stock (sometimes it's preferable, depending on the engine), if you get too far off the engine will run very poorly. If it were my bike I'd get the mechanicals done first before trying another TCI. Fix the things that you know are not set correctly before messing with anything else; eliminate the known variables.
    Franz likes this.
  27. mtnbikecrazy55
    Lol thread bumped from 2012?
  28. permissiontolandfmx
    Wow hadn't checked this thread in awhile. Thanks for all the advice.
  29. k-moe
    Due to a purchase made in 2013. Makes sense to me.
  30. CapnRedbeard
    CapnRedbeard Member
    London England
    K-moe, Your right permissiontoland advertised and I purchased, as he has more units others may wish to contact him? If he can send it to the UK then and it is as described. I will bump the thread for him. :)
    One good turn deserves another!
  31. permissiontolandfmx
    Thanks CapnReadbeard
  32. Fer93
    Fer93 New Member
    Nicaragua
    I'm having an issue with my XJ750, my CDI it's working fine but accidental I cut the two wired sockets and I don't know how to connect the línea with the pins on the CDI, can someone heló me with this?
  33. XJ550H
  34. Ddollar
    Ddollar New Member
    Washington
    I have an 82 xj550 t seca and im told woll interchange with the 650. Correct me if in wrong but id like to have 1 on my bike at a reasonable price or possible trade.. the one i had was stolen so ive wired HEI modules and no advance is still my issue. Thanks and please let me know
  35. XJ550H
    the tci for the 550 650 and 750 will start any of the xjs 80 to 83 but your bike will not run properly without the correct tci
    you need a tci for a 550 ? what do you consider a reasonable price?
  36. Ddollar
    Ddollar New Member
    Washington
    Im coming to find out how hard they are to come by and so i honestly dont want to offend u and low ball you. Im a biker and really just love the ride, the freedom and on this bike the balls she has for being a 550. If u dont think my 550 would run right with a 650 TCI can u explain your reasoning? Cause you have 650 TCI right?
  37. XJ550H
    I have the 550 tci and a few 650/750 tcis
    the timing is different on the 550 than the 650/750. we had a member using a 900 tci for his 550 and switched to 550 his problems were solved.
    the 550 parts in general are becoming harder to find on ebay even new parts needed parts
    ebay selling tci for 80$ my near by parts yard 160$
    place an ad in our wanted forum you will get some decent replies
  38. XJ550H
    from post above from chacal
    HCP412
    TID14-05
    4U8-10 (date code)
    4 + 5 terminals
    Advance curve:
    5* at 1,250 rpms
    Applications:
    see post above from chacal for the timing specs for other tci moduals
  39. Ddollar
    Ddollar New Member
    Washington
    Yep that sounds like the one that was in this bike. The blue is what i know. Now that seem like a pretty huge advance considering my knowledge on the HEI im trying which i believe only has a 17 - 36 degree curve.
  40. Ddollar
    Ddollar New Member
    Washington
    $80 sounds fair but i am skeptical purchasing used electronic on ebay. My whole purpose of joining this group is for knowledge and a bwtter sence of reliability in everything. See i would have felt dumb offering you $25. If you would sell me it i wouldnt have the money for a little while but if u hold on to it i will be buying it bfore too long
  41. Fer93
    Fer93 New Member
    Nicaragua
    I'm using two CDIs from bajaj, and my XJ750 is doing even better than with the original CDI, low and high speed working properly. I just came for a 479km trip and it's still working
  42. Ddollar
    Ddollar New Member
    Washington
    Cool. My bike runs a TCI ignition system.
  43. XJ550H
    there is a way to fix tci but sorry to say it may be a little more than you could do . it intimidates me too.
  44. XJ550H
    props to you. I am always impressed but the ingenuity of my neighbours from below our southern boarder in keeping motorcycles running
    Rooster53 likes this.
  45. Fer93
    Fer93 New Member
    Nicaragua
    I just fixed mi TCI unit, but I'll keep using the 2 CDI from bajaj, but I'm having issues with the carburators, do any of you gusy know how to regulate them on the XJ750? I never did that before, and the problem is that I don't have the tools to do it properly... Veré is a pic of my baby, I'm creating a Cafe Racer
