FactoryKiss Master Cylinder/Clutch Lever
Discussion in 'XJ Modifications' started by timbojim, Mar 9, 2012.
  1. timbojim
    timbojim Member
    Kelowna, BC, Canada
    Today I recieved my FactoryKiss Master Cylinder and clutch lever assembly. I slapped these on my 1982 XJ750 Seca, that I have been turning into a Cafe racer. My brother and friend also got some items from factorykiss, and seem to be happy with the products. Note: the clipons and gold levers are for my brother's '97 GSXR750. Also, ignore the handlbar setup as they are just for getting the feeling of clipons before I order a pair.
  2. Samson
    Samson Member
    Lombard, IL
    Those look nice, but if you are going to mount them that low, you have to check the clearance between the gas tank and the clamp screws on the clip-ons.
    When you turn the all the way to either side, the fork gets really close to the gas tank, and most clip-ons with rear facing clamp screws will not clear it… something I found out after I order my set (not factorykiss).
  3. timbojim
    timbojim Member
    Kelowna, BC, Canada
    I have already performed this test and found that works for me just fine, with the exception of about a millimeter on the throttle side. Fortunately it's an easy fix.
  4. Polock
    sometimes you can cut a set of regular bars to use instead of the straight clip on bars to get some rise or pull back, or just a different look
  5. timbojim
    timbojim Member
    Kelowna, BC, Canada
    I'm actually still deciding on which clipons to order, as there are a bunch of options. Should I go for partsnmore, or shoul I go for a set of eBay ones?
  6. kentownsend
    kentownsend Member
    portland, or
    Thats EXACTLY what i have been looking for! Where did you find the master cylinder/ handles from? I searched "FactoryKiss" And didnt see anything like that on their website.....
  7. timbojim
    timbojim Member
    Kelowna, BC, Canada
