fin damage .. what to do if anything?
Discussion in 'XJ Technical Chat' started by slackard, Aug 24, 2013.
  1. slackard
    slackard Active Member
    Earth, Terran System
    so i got this here fin damage on right side head. Looks like its been this way quite a while.
    It doesnt look like too much surface area loss, but it could create a uneven cooling or a hotspot in the head, and that concerns me -- maybe it shouldnt?
    Aside from some new aluminum stock and jbweld (or a tig welder), anyone have suggestions on how treat this damage? shoudl i even worry?
    You could have the fin built up with weld, but unless you are concerned about looks it isn't necessary for such a small amount of missing fin.
  3. Dano59
    Dano59 Member
    Charleston Illinois
    +1
  4. Dano59
    Dano59 Member
    Charleston Illinois
    +1
  5. RickCoMatic
    You dodged a bullet.
    If the Head got cracked closer to the Half-moon Plug, ... you might have sustained damage that would have created a leak and put you in a tough spot.
    I don't think you'll have a cooling issue.
    The thing to do is "Dress" the damaged area.
    A DREMEL with a Medium sanding drum will let you smooth-out and round-off the portions that L@@K damaged.
    You can also File those surfaces.
    To prevent the File from "Loading-up" with alloy, ... apply Blackboard Chalk to the File before attacking the jagged edges.
    If chalked, ... the File can be slapped against a Hammer Handle dislodging the buildup ... whereupon you re-chalk the File and continue.
  6. Dano59
    Dano59 Member
    Charleston Illinois
    Rick
    Cool tip on the file chalking
  7. adrian1
    adrian1 Active Member
    As stated. Dremel time
  8. bigfitz52
    My 550 has the corners knocked off a couple of fins too. I did as suggested above, carefully dressed them with my Dremel and they're virtually unnoticeable.
  9. spinalator
    spinalator Member
    Regina, CANADA
    I had a friend who tried to get matching dings on his KZ but you sound too conscientious for that! :D
