Final drive maintenance
Discussion in 'XJ Technical Chat' started by Lefty, Aug 2, 2007.
  1. Lefty
    Lefty Member
    Vancouver, BC
    Hey all, question about final drive gear maintenance.
    Basically, what should I be doing for my final drive to keep it in tip-top shape while I wait for my Haynes manual to arrive? The owner's manual I have isn't too helpful on the subject, but it's just the dumbed-down one that comes with XJs.
    Thanks!
    Lefty
  2. Lefty
    Lefty Member
    Vancouver, BC
    Nobody? Damn, it's going to be at least a week before I see the Haynes arrive :(
    Hopefully SalCycle has some insight for me on Monday!
  3. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Just change the gear oil every year. Use a GL-4 or GL-5 75/80 hypoid gear oil. Drain the oil from the bottom drain plug on the final drive case then fill to the bottom of the threads of the fill hole.
  4. RickCoMatic
    Lefty:
    There isn't a whole lot of maintenance to pull on the ass-end.
    At the beginning of every season; I just Flush my diff out and let it drip until all previous Hypoid is drained-out.
    Then, I put the drain plug in the bottom and fill it with the best Hypoid rated for High-speed that I can find.
  5. Robert
    Flush and fill Lefty, just like the man said. 80 weight is specified but the 75/80 will work just fine.
  6. Lefty
    Lefty Member
    Vancouver, BC
    Awesome, will pick up some hypoid when I get home and do a flush. I don't know if it's ever been done before.
    Thanks!
    C
