Final Drive Swap
Discussion in 'XJ Modifications' started by Ease, Nov 27, 2007.
  1. Ease
    Ease Member
    NL, Canada
    Anyone know off hand what the ratio is for the 83 seca 650 final drive?
    I'm thinking about doing a swap with an xs11 pumpkin for the better accelleration / lift, and giving up some top end speed. That is unless someone tells me it won't fit my wheel - or the ratios are the same...
  2. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    32:11
    BTW, if this is feasible, it might interest other people that an XS750/850 final drive is a bolt on replacement for the XS11, offering higher gearing and lower revs at highway speed. Somehow I don't think it's a bolt on for the XJ series though. They are also different in that they have a grease zerk for the shaft bearing at the differential.
  3. TIMEtoRIDE
    does 32:11 work out to 2.90:1 ?? my notes say the turbo's rear end is 4.179:1 and the xs11 is 3.30:1
    I'm demanding a re-count! [I'm from Florida]
    I've been looking for taller gears for the 81 seca 750 by 10% or so.
    any advice would be appreciated.
  4. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    I've been all through the gearing on the XJ's and they are all almost identical, except I believe the XJ900 has an extra tooth on the clutch hub, but don't quote me on that. I went over every combination, but there is really no difference between them. I believe the Viragos and VMax also use this final drive ratio. Parts bin engineering, Yamaha does it very well, and it makes perfect sense.
  5. Oldgoat
    Oldgoat Member
    Montreal
    For what it's worth: I had a V-Max & installed a Venture pumpkin to give lower revs at highway speeds. The Venture had one less tooth on the ring gear.
