Final gear sludge
Discussion in 'XJ Technical Chat' started by Dan Gardner, May 12, 2020.
  1. Dan Gardner
    Minneapolis, MN
    I just changed the oil in the final gear drive gear. It had a magnetic plug in it and it was covered in a pretty sludgy mess. Should I be worried? Or should I just be happy that I changed the oil before it got too bad?
    xj6504lyfe likes this.
  2. xj6504lyfe
    xj6504lyfe Member
    Norwich ny
    Mine was the same way, if you changed it last spring, bad news, but if its the first time its ever been changed ( most likely ), its normal.
    Dan Gardner likes this.
  3. Timbox
    That is normal, good thing you checked and changed the oil. Well done.
  4. Dan Gardner
    Minneapolis, MN
    Thanks guys. The bike is new to me so who knows when the last time it was changed. I think I might put a few miles on it and then change it again to see if it rinses out any more gunk.
  5. Jetfixer
    Relax you have nothing to get worked up about. There will always be a bit on the drain plug, just use the proper weight and good quality lube.
