First XJ! Need some help.
Discussion in 'XJ Technical Chat' started by Mxtlplck, Sep 22, 2022.
  1. Mxtlplck
    Mxtlplck New Member
    Kansas
    BDBF96C7-6C15-4056-8EFF-0A112B3589D5.jpeg 4748205A-D88F-4915-A1F1-12B1729441FA.jpeg Hello all. Just acquired my 3rd motorcycle. 1st was a 76 Yamaha XS650, but engine was locked up. This was about 6 years ago before I had any technical know-how. Second was a 84 Honda Magna 700, almost ran but it’s such a technical bike I traded for my current bike.
    1982 Yamaha XJ650 Maxim. Cleaning carbs currently, just replaced the petcock. Compression is great. Coils check out. Should run as soon as I finish here with the carbs.
    my questions: will a 650 Seca Turbo 4-1 stock header fit my Maxim? I found a used pair and I like the idea of a 4-1 without dropping $600 on a Mac exhaust. All im curious about is clearance. I can secure from there and planning on running my own pipes and muffler.
    Second Q: No power getting to my headlight connector. Everything else works, taillight, blinkers, etc. just the headlight. Fuse looks good…???
    Painting gas tank and panels. Prepping now, any color suggestions? My XS650 tank was orange with stripes. Pic attached. I loved the look. Lmk what y’all think.
    TIA!!!!!
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    Nope. Your stock exhaust looks good though?
    The headlight won’t turn on until the engine is running (or spins over fast enough to generate power and latch relay).
    Jetfixer likes this.
  3. Mxtlplck
    Mxtlplck New Member
    Kansas
    Boom. You are awesome. Thank you very much my friend, much appreciated.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Welcome to the forum!
  5. Simmy
    The Turbo 4-1 collector will mount to the bottom of the engine just like the OEM Maxim collector.
    Your Maxim head pipes will even insert into the Turbo collector.
    However, your LH pedestal for the centre stand will prevent the Turbo collector from fitting and would need to be sawed off to fit.
    jayrodoh likes this.
  6. Mxtlplck
    Mxtlplck New Member
    Kansas
    Hmm. I can do that. These pipes are only $50, so can’t hurt to try. Much appreciated
