fj engine in an xj chassis????
Discussion in 'XJ Modifications' started by bossnoss77, Nov 8, 2009.
  1. bossnoss77
    bossnoss77 Member
    orem utah
    hey any one on here no if an fj1100 84/85 will fit in a 1982 xj seca 750 chassis??? i want to change out my forks and tires and wjells and brakes to all disc and chain drive. I want to run some sportbike stuff. sic thanks
  2. bossnoss77
    bossnoss77 Member
    orem utah
    this is my bike now was an 1982 seca 750
  3. bossnoss77
    bossnoss77 Member
    orem utah
    pic
  4. TIMEtoRIDE
    I think it'll ALMOST fit, meaning basically no.
    I thought of taking the 400 pound Seca 550 and adding the 1100 engine, but that won't work without major frame welding and stretching.
    You need to measure the 2 engines.
    You would need to do NASCAR quality tube welding for strength.
    Everything needs to be "square" and "true"
    The swingarm is all wrong.
    But you'd end up with a serious HOSS of a bike !!
    Just brush up on your German a bit and build this. . .
    http://www.youtube.com/watch?v=QK7SV3reUgM
  5. bossnoss77
    bossnoss77 Member
    orem utah
    yeah that 1100 pocket bike is sic!! that is a little crazier than what i want, but not to far off. I have a ninja 600 that i parted out. so i an going to change out the whole front end: forks brakes wheel etc. but then my wheels wont match and i still have a rear drum brake, i found an fj motor for cheap. i was going to try and mod my chassis to accept it and a new swingarm this winter. then i could run rear disc brakes and chain so I could change my gearing. and it would be hella fast. that is the best part
  6. Mikko
    Mikko Member
    Finland
  7. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    That's one way to cut the bikes weight down a bit. :)
