FJ600 Almost success
Discussion in 'XJ Technical Chat' started by JPaganel, Jul 24, 2014.
  1. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Got the new main jets of the correct size and put them in.
    With the correct jets, it started with choke and idled. Throttle worked normally and evenly.
    The "almost" part comes from the fact that there was a steady stream of gas from the left overflow tube.
    So, floats need to be set. No surprise here, I didn't think I was done, just wanted to see a little bit of progress.
  2. bigfitz52
    You probably just filled the crankcase up with gas too.
    Give it the "sniff test."
  3. JPaganel
    Minneapolis
    I will, certainly, check.
    I think the tubes are there to prevent exactly that, though.
  4. bigfitz52
    If it's puking enough gas to come out the "overflow" tube it could also have puked enough gas down the intake tract to pollute the oil.
