FJ600 - Broken Piece Under Chain Cover
Discussion in 'XJ Technical Chat' started by mreinsmith, Feb 6, 2013.
  1. mreinsmith
    mreinsmith New Member
    Southeast, PA
    When we removed the chain cover we found a broken plastic piece inside.
    We can't figure out what it is from any of the parts explosions in the manual.
    It appears that it was circular and possibly had a small spring in it
    Pictures are below
    TIA
    M
  2. bigfitz52
  3. mreinsmith
    Southeast, PA
    the neutral switch seems to be intact.
    I've been looking at the parts diagrams, Intparticular the diagram for "crankcase cover" and "Electrical 2" and I still can't figure out what the heck it is.
    any other ideas?
    M
  4. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    It looks to me that the chain is hitting the plastic sleeve around the shifter shaft. Adjust the chain.
  5. bigfitz52
    There is one off-hand possibility; and that's maybe it's not from behind that cover at all.
    Oil seals have springs in them. Did your sprocket-carrier oil seal self destruct, and the pieces go for a ride on the chain only to get caught there?
    This one?
  6. mreinsmith
    Southeast, PA
    I'll check that out
    M
  7. mreinsmith
    Southeast, PA
    That DOES look like a seal spring!
    I'll check that out too
    M
  8. mreinsmith
    Southeast, PA
    Sure enough, the grease seal is missing from the that side of the wheel!
    So that begs the question, do you think I should replace the bearing as well?
  9. Polock
    what holds that counter shaft bearing in? looks like there's a snap ring groove without a snap ring in it
  10. bigfitz52
    You should replace them all. That picture is from my "how-to" on replacing rear wheel bearings, done on my chain-driven 550 Seca: http://xjbikes.com/Forums/viewtopic/t=35134.html Have at it! I covered both the old school hammer and punch method, plus the use of bearing extractors. If you use fully sealed bearings, that seal becomes redundant; but I'd install it anyway.
    Ask questions if you have any. And check that chain and sprockets; if you're not familiar with the correct way to check a sprocket for wear say so and I'll happily hook you up.
    (I love getting long-distance diagoses right, BTW. 8) )
