FJ600, YX600 cylinder head compatibility
Discussion in 'XJ Technical Chat' started by j_ondrusek, Mar 9, 2018.
  1. j_ondrusek
    j_ondrusek New Member
    Seattle, WA
    Hi FJ folks!
    I have a (best guess) 1986 YX600 engine in a pretty bad shape. Cylinder head might be recoverable, but camshafts are definitely done. I have looked around eBay and found:
    • a few YX600 heads, no cams
    • lots of FJ600 heads and cams (around 1984)
    Would anybody happen to know, whether FJ600 and YX600 heads or at least valves and cams are compatible? I know they share gaskets and valve covers.
    Thanks in advance!
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  3. chacal
    It appears that the head is the same, as well as the exhaust camshaft. The intake camshaft is different (probably a slightly different profile) but since the basic head casting is the same, the cams will be interchangable. The FJ600 cam is probably a little bit more aggressive than the YX600 camshaft, but that's just a guess. Intake and exhaust valves and associated bits are all the same between FJ600 and YX600 engines.
    j_ondrusek and k-moe like this.
  4. j_ondrusek
    Seattle, WA
    Glad to hear that, this makes my rebuild much easier, many thanks!
