float bowl question
Discussion in 'XJ Technical Chat' started by alexdc03, Aug 26, 2009.
  1. alexdc03
    alexdc03 Member
    My float needle has slight wear groove in it so gas will seep to the piston, do I replace just the needle or do I need to replace the seat also?
    thanks
  2. Broke_Dirty_Maxim
    Broke_Dirty_Maxim Member
    Jacksonville, NC
    You should be able to replace just the needle, provided it is of the exact same type. The reason being, there might be a slight difference in geometry between the different brands of needle and seat kits. So they may not all be compatible between each other.
    Personally, I would save myself the aggravation of having to redo the job if they don't match, and I would just replace them as a set.
