Float test question
Discussion in 'XJ Technical Chat' started by jvitzu, Jun 10, 2010.
  1. jvitzu
    jvitzu Member
    Greensboro, NC
    I feel dumb for asking this, but its been bothering me:
    When I'm doing a float test with a clear tube, I move the tube up and down. Lets say I've moved the tube in such a way that the entire foot-length of it is filled with fuel. Then, I raise the tube so that almost all of it goes back into the carburetor. Where does that fuel go? Does it spill out of the carb into the manifold/intake?
  2. TIMEtoRIDE
    NO, it simply over-fills the float bowl chamber, and shuts off the needle/seat.
    You only get a true reading if you do not move the clear tube.
    The extra fuel would induce a slight error. Drain and re-fill.
    Carl Sagan had some great ideas !
  3. bigfitz52
    You can move it around a bit, but TIME is right, you don't want to do what you described you will get a false reading.
  4. jvitzu
    jvitzu Member
    Greensboro, NC
    Well noted, thanks. I'd better start over heh.
  5. MiCarl
    This situation may be the reason the service manual specifies to check the level with the engine running.
    It's also important to have no air in your fluid column as it will interfere with your reading.
