Food for thought oil pressure gauge
Discussion in 'XJ Modifications' started by 12Rant, Aug 28, 2014.
  1. 12Rant
    12Rant New Member
    Nortern Ontario
    I just bought a 1982 Xj 650 rj Seca and I was wondering if you can add a mechanical oil pressure gauge and if so where can you tap into the engine to connect it. Thanks.
  2. Krafty
    Krafty Member
    Point Clark ON
    you cant put an oil pressure gauge on something without an oil pump
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    eh.? xj's have no oil pump!.?
    don't understand your statement.
    the high pressure take off is available at the large allen cap screw at the bottom of the engine on either side
    the one here under the "Yamaha" cover.
    I believe some engines have another takeoff from a 8mm bolt on the cylinder head.
    someone more familiar to your engine may know exactly where
    stu
  4. TIMEtoRIDE
    Taking the pressure at the head will give a "false low" reading.
  5. scruff
    scruff New Member
    australia
    howdy guys,this is what i did to check mine.this is a 60psi gauge.cheers scruff
  6. bigfitz52
    Just be careful with that. You've tapped into the end of the main crank oil gallery; a leak there could quickly destroy the motor.
    As for the presence of an oil pump: Yes, the XJs have an oil pump. In the 550/600s, it is gear driven; in the shafties it is chain driven. It's located behind the clutch in both series.
  7. Krafty
    Krafty Member
    Point Clark ON
    learn something new everyday, still not used to the ins and outs of the overhead cams yet.
    my head was stuck in 2 stroke la la land
  8. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Well to rub it in a little, most two strokes have an oil pump, too. Otherwise one would have to mix oil and gas like a caveman.
  9. Krafty
    Krafty Member
    Point Clark ON
    all my two strokes are mixed gas.... thank you very much
    not many chainsaws where you are?
    or weed eaters, leaf blowers , motocross bikes, oil injected snowmobiles (okay bad example), two stroke quads , ect..
  10. Bigshankhank
    Bastrop, TX
    Well, yes I love my two-cycle lawn tools, however this is a motorcycle forum so I figured the discussion would stay in that realm. However you are correct about the motocross bikes, most of my two stroke experience has been with 70's bikes from Yamaha and Kawasaki all of which have oil pumps.
  11. 12Rant
    12Rant New Member
    Nortern Ontario
    Thanks for your replies. Just thought the it might be like Small Block Chev where you can just screw the Oil Pressure gauge in where the Oil Light sensor taps in.
  12. bensalf
    yorkshire ,england
    nope, sorry, oil light is for oil level on these bikes , not pressure
    stu
