For Sell
Discussion in 'For Sale, Trade/Swap, Wanted' started by prosper, Feb 20, 2010.
  1. prosper
    prosper New Member
    1982 Yamaha Maxim 550
    35k miles
    Located in Winchester VA
    This pains me to type but financially I have to give up one and the maxim make the most sense.
    The carbs were cleaned and balanced in October, I also have put a new battery, and pitcock valve in,
    This does need some work but not a lot to get it running on the road, I was riding to and from work every day before winter decide to set in.
    I have been going out and starting it about once to twice a week to make sure everything is good.
    I am working on digging out my garage so I can get it out side to take pictures. If you would like to see let me know.
    I am asking 500 Firm for it you pick it up, sorry that is the rock bottom I can go. I have a free and clear title that I can give you on completion of the sale
  2. Grynen
    Grynen Member
    Holland Landing
    Where are you located, it will help with people's decisions.
  3. prosper
    prosper New Member
    Didn't think about that I will add it to the original post
  4. iwingameover
    iwingameover Active Member
    Did you get pictures yet? and what work needs done to it?
  5. prosper
    prosper New Member
    More coming
  6. prosper
    prosper New Member
    Right Side
  7. prosper
    prosper New Member
    Seat
    If you look at the real flasher the plastic piece for that has broke, I do have those at my house for the rear I have not put them on yet
      File size:
      46.6 KB
      1,155
  8. prosper
    prosper New Member
    The Speedometer works find, the tech does not work and I have worked on that yet
  9. prosper
    prosper New Member
    Front and back Tire
  10. prosper
    prosper New Member
    Here is the known work that has to be done,
    Brake pads are low but ok for now, tach gauge does not work,
    and the left turn signal turn on solid but do not flash, they did about a week before I parked it. I believe this is just a connection issue in the switch because they did flash for a while if I turn them on and off.
    And last if you look at the rear tire pic you can see the exhaust, that is by the previous owner, I have never got pulled over
    Any other questions?
  11. mcrwt644
    mcrwt644 Member
    Winchester, VA
    Put that sucker on CL! put it on the DC site though, not the local winchester site. That thing will be history in no time, especially with the warmer wx coming this week, it'll have folks getting the urge to ride.
