Fork rust help during rebuild
Discussion in 'XJ Technical Chat' started by heelflip131313, Mar 20, 2011.
  1. heelflip131313
    heelflip131313 Member
    Riverside, CA
    What is the best way to clean rust off the screw cap and Oil Seal Retaining Clips grove? I am rebuilding my first set of forks and they need to be touched up.
  2. bigfitz52
    Are they already apart, or do you need to free up rusted-in-place parts?
  3. heelflip131313
    Riverside, CA
    I have everything apart. One air valve didn't have an o ring so there is a little surface rust.
  4. bigfitz52
    Just polish it off with Scotchbrite.
  5. heelflip131313
    Riverside, CA
    Thanks Fitz. The scotchbrite worked like a charm. What is the best way to clean the tubes out? I see that people are suggesting to flush it with fork oil but that seems a little costly. Can I use something else like brake cleaner or motor oil?
