Fork sizes and swaps
Discussion in 'XJ Technical Chat' started by JPaganel, Oct 27, 2014.
  1. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    I was looking at a listing of fork sizes and it said that 550 Maxim and Seca had different size forks. I know the lowers are different, but is there really a diameter difference in the inner tubes? The list said Maxim was 36mm and Seca was 35mm.
    I am kind of musing about swapping out the stock Seca fork for something with dual disks. Even though it's a pretty light bike, it kinda feels like it could use more brakes at times.
    Maybe I could fit 650 Seca forks? Anyone know what their dimensions are?
  2. Rooster53
  3. Polock
    you'd be farther ahead to change the whole front end
  4. JPaganel
    Minneapolis
    That list says FJ600 has the same fork tubes. That might be a nice option. I can measure the one I have and see if it's true.
    Triple trees and all, you mean?
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    Does the US 550 front wheel have the blanking rubber for a second disc ? If so you could try and source a Euro fork slider
    with the caliper lugs on - should be cheap and light enough to send at not too much cost. All EU 550s had twin discs..
  6. JPaganel
    Minneapolis
    Yes, the wheel does have the delete plate.
    However, I found that EU-spec fork lowers are different on both sides and don't cross over to any other bike. The right lower is not the same s US-spec right lower. The US caliper is also not the same as the EU right caliper.
  7. a100man
    Bedford, UK
    Ah. My bad. I guess teh US disc may be bigger diameter to compensate in that case..
    It does beg the question though ' Why the hell did they do that ?'
    Good luck with your quest.
  8. JPaganel
    Minneapolis
    Yeah, been scratching my head over that one.
  9. JPaganel
    Minneapolis
    Incidentally, here are the part numbers I found in my research. All of them show as unavailable in the catalogs, so this is strictly informational.
    Euro spec:
    Tube,outer 1 clear buffing
    4G0-23126-00-38
    Tube,outer 2 clear buffing
    4G0-23136-00-38
    Caliper assy
    4L3-25810-30-00
    Caliper assy
    4L3-25810-20-00
    US spec:
    Tube, Outer 1 CLEAR BUFFING
    4U8-23126-00-38
    Tube, Outer 2 CLEAR BUFFING
    4U8-23136-00-38
    Caliper Assembly Right
    23W-25810-02-00
  10. a100man
    Bedford, UK
    Hi
    Are you assuming they're different due to different part nos or have you had a chance for a side by side comparison? Could
    just be Yamaha playing silly buggers with part numbers-it's bee known before i think.
    I have euro brake parts and forks I can measure if it helps..
    James
  11. JPaganel
    Minneapolis
    Calipers and tubes look different in the parts drawings.
    Of course, that could be inaccurate, too.
