Frickin' over-tight 30 year old screws!
Discussion in 'XJ Technical Chat' started by hbennick, Aug 3, 2010.
  1. hbennick
    hbennick Member
    I need to get to my clutch, mainly because I don't read directions. The top most screw on the right crank case cover is tighter than a nun's knees, and the slots on the head are pretty much worn down to nothing.
    I've ordered some screw extractors off of ebay, since I'm going out of town for a few days and I can wait for shipping. I've been trying for 2 weeks to find time to get out to the garage and work on this, and now I'm stopped again! Grrrr.....
  2. Polock
    you can pretty much beat new slots in a screw and take it out at the same time with a hand impact driver and a three pound hammer
  3. hbennick
    hbennick Member
    Tried that, the metal just shreds.
  4. bigfitz52
  5. RickCoMatic
    When I get one of those stubborn screws ... I show it no mercy.
    Grab on to it ... real tight ... with Vice Grips or a Miniature Pipe Wrench.
    In the case of Vice Grips ... "Crappy-Old" Vice Grips with worn-down jaws ... won't cut it. Use the good ones.
    Tape the Grips closed with Electrical Tape.
    Swat the Vice Grips a good smack with a Hammer Handle.
    The Mini-Pipe Wrench!
    Get a GOOD Tight starting grip.
    Apply FIRM Torque in the Undo dye-reck-shunn !
    Beat the Handle of the 'Lil-Pipe with a heavy something!
    Don't heat it.
    Or, if you do ... just the Head twists off.
    Throw alll the old fasteners away and get a Stainless or Titanium Kit.
  6. Polock
    just remember what Clint said
  7. stryker
    stryker Member
    the easiest way to do it if you haven't stripped the screw is to apply more leverage. find a pipe or something in your garage and slide it onto the ratchet so that you basically have a really long handle, then turn.
  8. TIMEtoRIDE
    Sometimes if you tap on it like it's a nail it helps release the threads and the Kroil can soak in further. Then loosen AND tighten just a little, like a very small wiggling action, breaks threads loose one at a time.
    But these bolts ARE grade 1 crap.
  9. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    To add what TIME wrote when you get the screw out abit spray some in some Kroil in then tighten, repeat as needed.
  10. RickCoMatic
    I think you should get rid of as many of the CHEAP Fasteners that are on the Bike as your good fortune permits.
    I envy the Members who have gotten-out all the Intake Manifold Cap Screws.
    You can get KITS relatively cheaply that will replace the Engine and Carbs.
    If you don't care to go with a Stainless-look or want to keep it LOOKING Stock.
    Replace the soft stuff with a higher grade of Fastener.
    Every now and then ... you get the opportunity to get Stainless Fasteners for the Bike at a fraction of the cost for what you'd pay ala-carte.
    Like this deal ... on Ebay!!!
    http://cgi.ebay.com/ebaymotors/ws/eBayI ... K:MEWAX:IT
  11. schooter
  12. RickCoMatic
