Front Brake Cable
Discussion in 'XJ Technical Chat' started by Bjarvis, Oct 23, 2012.
  1. Bjarvis
    Bjarvis Member
    Victoria BC Canada
    Not sure if the PO's replaced the front brake cable or not - hopefully the attached photo is clear enough to see! IS anyone able to tell me if this is likely the original cable. I understand from reading various posts, that it is highly recommended to replace with a "braided stainless" cable. Would anyone happen to have a photo of a new cable ?
  2. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    rubber hoses "should" have a date stamp on them. Don't trust the PO either. Mine REPLACED the brake cables old brake cables with "good used" ones with a date code of 01/85. personally, i would just get the stainless ones anyway
  3. bigfitz52
    They're not cables, they're hoses.
    The one in your pic appears to be original; it should have "date codes" either molded into the rubber or stamped in the metal ferrule on one end.
    If original, replace. If over 4 years old, replace.
    Stainless lines are a worthwhile upgrade. They're the single biggest imporvement you can make to the stock brake.
