Front Brake Pads Wearing at an Angle
Discussion in 'XJ Technical Chat' started by stephen colbert, Jul 9, 2015.
  1. stephen colbert
    stephen colbert New Member
    NA
    Bought an XJ last weekend, haven't ridden it since then but I have been slowly taking it apart.
    I removed my front wheel today. When I inspected the brake pads, I found they were worn at an angle like so |/ /|. What is causing this and how can I make sure they wear correctly when I put new pads on?
    Also, side note, we're supposed to use 20w/50 oil right? I was wondering what your favorite brand is for when I do an oil change.
    Thanks!
  2. Beekman
    Beekman XJ Grasshopper
    Erin, Ontario
    If I recall correctly that is how they are supposed to wear. This is due to the fact that the caliper mounts to the fork via a single bolt through the middle of the caliper causing a slight pivot motion when braking force is applied.
    Not exactly sure what the reasoning for this design is.
    I've run 10W-40 Motul for the last 12000km and ha dno problems. Just make sure it is motorcycle specific safe for wet clutches.
  3. Beekman
    Erin, Ontario
    Side note on the oil however, the majority of my riding is done in air temps between 15-25 °C, lower in April, May & October, slightly higher through July & August but it is rarely above 30°C here, especially since most of my riding is done after work, not in full heat of the sun.
    If you ride in higher temps you probably want a higher viscosity.
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
  5. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Stephen, consider adding you bike model in your signature.
    Different XJ's have different characteristics.
    My XJ650 Maxim has brake pads as Beekman (and you) described. That is normal.
    Matti has you covered on the oil thing.
    JimBill likes this.
  6. XJ550H
    have you or are you planning on a brake caliper rebuild while you have it off of the bike?
    when you replace the pads you may have to make the hole in the pad larger to fit your caliper pin with out binding.
  7. Luis
    Luis Member
    Seacoast NH
  8. hogfiddles
    650 pads don't "wear at that angle" as in 'cause that angle'. They're made that way... Don't worry, you're ok.
    JimBill likes this.
  9. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Taking Dave's word should be enough, but since you're new I'll second it. I recently (within a year or two) rebuilt my brakes and the new pads were angled from factory.
    Also, I'm a big fan of your show. Welcome to the forums.
  10. stephen colbert
    NA
    Might as well.
    Perfect. Thanks
    I feel like I have learned so much in the past few days reading this forum. I need to marinate a little.
  11. Stumplifter
    near Irma, WI
    I recommend a bacon infused bourbon for your marinade.
    BaldWonder likes this.
  12. BaldWonder
    Oberlin, OH
    Stumplifter and Luis like this.
  13. Luis
    Luis Member
    Seacoast NH
    good 3 fingers.... mmmm
  14. MattiThundrrr
    Friday is a great day for marinating. A healthy dose, and allow brain to soak all weekend! Bourbon is ok, but the buzz is too mellow. You 'Mericans need good Canadian rye! Makes ya CRAZY!! Something like 40Creek. 3 fingers go great with 2 ice cubes, and/or a little splash of ginger ale for color. I'd post a picture, but I can't seem to keep a bottle around the house. Always ends up empty!
  15. k-moe
    If it's not Scottish it's crap!
    Carry on.
  16. BaldWonder
    Oberlin, OH
    I know the feeling. My wife keeps drinking all of our Cleveland Whiskey!
  17. BaldWonder
    Oberlin, OH
    PS, I love that this thread went:
    OP: Hey, my brakes are funny.
    Everyone else: Nah, you're fine. BACON! WHISKEY!
    Stumplifter likes this.
  18. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Even when she's not around? Iirc all good tasting liquors have a high evaporation ratio.
    Gary H.
  19. stephen colbert
    NA
    Whiskey is eventually the answer to every problem. ;)
    BaldWonder and Stumplifter like this.
  20. MattiThundrrr
    Whiskey river, don't run dry,
    You're all I've got to take care of me
    As for that, I blame the cats!
