Front brakes locked
Discussion in 'XJ Technical Chat' started by joejr2, Sep 12, 2020.
  1. joejr2
    Santa Fe,NM
    I took my 82 650 maxim for a test ride and the front brakes locked.They released when
    I let pressure off the bleeder. The caliper was spotlessly rebuilt, so it must be the relief
    hole in the MC. Can one clean that little hole out with the fluid and piston still in place
    in the MC ?
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Don't know, but with brakes i would rebuild the MC with the same effort you put into the caliper.
  3. k-moe
    You can, but whatever is in there will just float around and get into the relief valve again.
    It's best to pull the M/C for cleaning.
    Were the brake lines replaced?
  4. Timbox
    Timbox Well-Known Member
    Yep need to do a much better job of cleaning and flushing. I would guess the MC relieve hole is getting plugged not letting the fluid back into the MC. That is what keeps the pressure in the lines and on the pucks in the calibers.
  5. joejr2
    Santa Fe,NM
    When I did the brakes on that maxim, I did a really good job of
    cleaning the caliper and m.c. including the tiny relief hole. I think
    crud came from the old lines and then blocked the relief hole. The
    lines I used were flexible and in good shape but sat in a box of dirty
    parts for a few years. I should have at least flushed them with brake cleaner
    And blew them out with compressed air.
    Timbox likes this.
  6. bigfitz52
    No, you should have replaced them. "Flexible" and visually "in good shape" does not negate 30+ years' AGE. The brake lines have many layers; the innermost layer, the one the fluid travels through, cracks and crumbles over time. Flushing with brake cleaner and compressed air will not fix.
    see: https://xjbikes.com/forums/threads/why-you-need-to-replace-original-brake-lines-w-pics.41400/ which includes pictures of the condition...
    REPLACE 30 year old brake lines. PERIOD.
    biggs500, cgutz and k-moe like this.
