Front brakes
Discussion in 'XJ Technical Chat' started by randyd81, Feb 20, 2014.
  1. randyd81
    randyd81 Member
    St Joseph Missouri
    Can anyone tell me how to get the brake pistons compressed to make room for the new pads?
  2. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    A big ol' C-clamp should do the trick.
  3. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Rebuild them...
    I did mine and the pads had plenty of room.
    Master cylinder
    Brake lines
    Pads
    Calipers
    And. Rear brake.
    It will make you happy happy. :):):)
  4. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    If they are really worn down there may have been more brake fluid added to the M/C, so you may want to remove a little so that the fluid you are compressing has some where to go. Just a thought....
  5. bigfitz52
    This is the only viable solution. The original caliper seals were only supposed to have lasted TWO years.
  6. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    Hey, Fitz. I just noticed your updated location. Might I suggest fur-lined boxers for the "wedding tackle".
