front caliper loose?
Discussion in 'XJ Technical Chat' started by mainexj550, May 28, 2007.
  1. mainexj550
    mainexj550 Member
    maine
    Hello all,
    I have a xj550 with a bit over 31k on it. I have been noticing a clunking noise when going over rough stuff and tracked the noise to my front caliper. It has a bit of play around the pin. Has anyone else experienced this? I don't see the pin in the rebuild kits for the calipers. Finally, is this normal? Brakes do work fine.
    thanks
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    I think there are a couple of rubber boots on that pin that keep it from rattling. Maybe they wore out?
