1. Dec 26, 2024: XJBikes.com server migration work has been is completed. Thank you for your patience. SnoSheriff
front end swap
Discussion in 'For Sale, Trade/Swap, Wanted' started by randomxj2012, Apr 9, 2013.
  1. randomxj2012
    randomxj2012 Member
    xj750 or xj650 r6 front end swap
    i have a 2006 yamaha r6 front end for sale its not the inverted ones but the r6s model to keep that stock look comes with bearings so its a straight install comes with brakes and triple trees no need to search for more parts
    300 obo
  2. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Pictures? Interesting if it truly is a bolt-on-kit type of swap...
  3. randomxj2012
    randomxj2012 Member
    i have the bearing so itll go straigh into your triple tree all you need is our controls and some clipns or you can just drill the top triplr like alot of people do
  4. mtnbikecrazy55
    damn, if it would fit a 550 without it looking like overkill it would be soooooo tempting.
    IMO a 650 seca would be the perfect bike to do it to - like this guy did:
    http://xjbikes.com/Forums/viewtopic/t=4 ... art=0.html
    DAYMN that looks good.
    I suppose a 750 seca would look sharp too, but, the 650 being lighter compared to the heavier 750.
  5. zap2504
    zap2504 Member
    Middletown, PA
    Actually, that is Clownman's XJ650 Maxim conversion (in XJ Modifications). The 650 frame is almost identical to the 750, the tail is chopped and he used a 750 Seca tank so I'm guessing that there would be no weight difference in using a 750 Seca or Maxim vs a 650 Maxim. But the original poster says that his forks are not the inverted version R6, unlike Clownman's (he has a separate write-up on his front end swap too). If so, it might look more like the stock XJ front end (with a different front wheel). Maybe something like this? [​IMG]
  6. randomxj2012
    randomxj2012 Member
    it would be like the pics above its not the inverted ones i wanted the stock look but with way better handli ng and braking.. i dropped my bike so i sold it and have this setup sitting around.. so the first 250 plus shipping takes it
  7. bostonXJ
    bostonXJ Member
    Mansfield, Ma
    Would this work on a 550 seca?
