front fork air pressure?
Discussion in 'XJ Modifications' started by bikeman, Jan 20, 2014.
  1. bikeman
    bikeman New Member
    new hampshire
    What is the correct amount of air pressure in the forks of a 1982 seca xj750r
  2. z32800
    z32800 Member
    Wellington New Zealand
    Std recomended pressure on my 750 (XJ900 frame) is 5.7psi max is 17.1psi, I run mine on about 9psi. Manual says NEVER EXCEED the MAX or oil seal damage may occure.
  3. k-moe
    The correct amount will depend on your preference, and how much total weight (bike, rider, passenger, and gear) you have. The additional air pressure is acting as additional spring preload. As z32800 stated, never exceed max pressure. Personally I run without any additional air pressure unless I have a passenger.
  4. bikeman
    bikeman New Member
    new hampshire
    thanks guys thats great
  5. TIMEtoRIDE
    And the safest way to load the pressure is to fill a portable tank to the desired pressure, and then fill the bike.
  6. k-moe
    Almost. The safest way is to use a hand pump with a built in pressure gauge.
  7. bendoza
    bendoza Member
    portland, or
    ^ thats what i do. doest take more than a pump depending.
  8. k-moe
    And you can carry it with you on a trip. I keep a collapsable bicycle pump in my tool tube.
  9. happydog500
    happydog500 Member
    Northwest
    I find my 750 runs good with a little more pressure. I'm getting pretty heavy so mine drives good at 12-15lbs. I tried 10lbs but kept bottoming out over jumps. :)
    Chris.
