Front wheel removal.
Discussion in 'XJ Technical Chat' started by Stone, Feb 13, 2012.
  1. Stone
    Stone Member
    Hi, I noticed when removing my front tire it didnt have the bolt that clamps sideways on the forks, I don't know how better to describe this so I hope someone knows what I mean. It is supposed to be the first bolt you remove.
    I was trying to find a size for this bolt so I could get a replacement.
    Any help is appreciated thanks Much.
  2. Stone
    Stone Member
    Picture to make it easier. it is whats circled in red.
      File size:
      106.6 KB
  3. MiCarl
    It's called a pinch bolt and it's important.
    I think it's M8, but don't know the length or pitch. The correct pitch will be important for the torque spec.
  4. theadbrewer
    theadbrewer Member
    Roseville MN
    OMG yes you do need that.
  5. MiGhost
    MiGhost Well-Known Member
    That pinch bolt would be the following part
    97013-08045-00 Yamaha BOLT
    It is an M8 X 45 mm bolt. You can get a replacement at any hardware store. You will also need a flat washer, and nut to go along with the bolt.
    Install the bolt from the top with the washer, and nut on the bottom.
    Axle pinch bolt torque 14.5 ft lb.
    Ghost
  6. hogfiddles
    Yeah, if you don't put that in, your axle is gonna wobble to-and-fro.........you know what will wobble next--
    dave fox
  7. ken007
    ken007 Member
    Brisbane, Australia
    do the pinch bolt to torque after you do the axle nut to torgue, so ive been instructed
  8. Dannymax
    Dannymax Member
    East central NY
    Correct....axle first, then the pinch bolt.
  9. Stone
    Stone Member
    Thank you everyone.
  10. bigfitz52
    ***the italics and bolding are mine*** Carl raises an important point.
    And he still doesn't. DO NOT assume a "hardware store" bolt to be the same thread pitch; quite often they ARE NOT.
    Hold off until somebody can give you the correct thread pitch as well. I can do it in about 4 hours from right now, when I get home to my books and bikes.
  11. Stone
    Stone Member
    I got one ordered through the dealer, Thanks for the help/.
  12. bigfitz52
    Ouch.
    You need to learn about XJ4Ever, our resident parts supplier. Click the logo/link in the site banner at upper right, PM member chacal or send an email to 'info AT XJ4Ever dot com.'
    His catalog is in the "XJ4Ever - Supporting Vendor" forum. Without him, very few of us would be able to pull this off.
    You'll go broke buying parts from the dealer.
  13. Stone
    Stone Member
    Shoot , Good to know for next time thanks.
  14. MiGhost
    Hardware Lesson #1
    Yamaha:
    97013-08045-00 BOLT $3.17 (1 EA)
    92990-08100-00 WASHER, SPRING $0.60 (1 EA)
    95333-08600-00 NUT $1.85 (1 EA)
    Total $5.62
    Fastenal: (Grade 8 equivalent)
    M8-1.25 x 45mm Class 10.9 Plain Cap Screw $0.7515(1 EA)
    M8 Plain Finish Split Lock Washer $0.0496(1 EA)
    M8-1.25 Plain Finish Steel Class 10 Hex Nut $0.1665(1 EA)
    Total $0.9676
    Without a doubt. XJ4ever can supply the hardware at a comparable price.
    The dealership is in the businees of selling bikes. Not bolts!
    Ghost
