Frustrated! Wheel bearing woes
Discussion in 'XJ Technical Chat' started by Hotcakesman, Mar 21, 2014.
  1. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    trying to do work on my bike tonight and all of it
    went terrible
    tried to balance the bike on the stand.. took off the
    front wheel and the bike stand unmounted and
    slipped forward onto the floor
    at this point I am unable to get it back onto the stand
    I have it balanced upright now, till my roomate
    can help me get it back onto the stand and I brace
    it another way
    so taking the exhaust off is out
    started to "attempt" to change front wheel bearings
    is there any way to do this without a bearing extractor?
    or do I have to pony up the money for a tool I will
    use for 30 minutes
    any ideas or help would be appreciated
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
    actually you would only use the tool for maybe more than a minute per wheel. it is possible to push the spacer tube to one side so you can drift out the wheel bearings but it is not as easy as using the extractor tool. I bought the tool because I have 2 bikes so I will get to use my extractor for a supposed combined time of about 5 minutes.
    CN
  3. adrian1
    adrian1 Active Member
    You can belt them out with a screwdriver...its ugly though. Use the old bearings as a drive to tap the new freezer cooled bearings in.
  4. MiCarl
    I'm not a big fan of the bearing extractors. They work on nice clean new stuff but often have trouble with something that's been corroding in place for years.
    I like to weld a bolt into one of the bearings. Then I can bang on it with a drift to get the bearing out. Once one bearing and the spacer are out it's pretty easy to get to the back of the other one. If you don't have a welder it should be pretty easy to find someone who can tack one in there.
  5. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    After spending hours with drivers trying to punch my wheel bearings out and not getting any purchase due to the spacer, I broke down and bought the bearing extractor set chacal sells. I even bought all the different sizes should a need arise.
    Consider the time spent trying to do it some other way, to the minute you'll spend using the tool. You might find more value in that.
    If I was near you (I'm in washington DC) I would even offer to stop by and lend you the tool. Never hurts to help someone else out if they don't want to purchase one, and get more use out of a tool.
  6. Hotcakesman
    South Dakota
    maybe someone would let me pay the cost to send it my way
    via pay pal and then I just mail it back when done?
    I dunno.. I doubt it is a tool I will ever use again
    which is shame
  7. bigfitz52
    Look in my rear wheel bearing article: http://xjbikes.com/Forums/viewtopic/t=35134.html skip past the use of the extractors.
    Look at the section on removing bearings "the old school way" starting with the 16th pic in the article.
    This is pic #18-- this technique will work the same, front or rear wheel. You need to displace the spacer tube enough to get a punch against the bearing on the opposite side and knock it out.
  8. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    That was a good answer Fitz. That is how I got mine out then I used a long socket to beat out the other side. Only took a few hits.
  9. Polock
    your overlooking the part about hitting one side then the other. once they get cocckked there stuck
  10. Hamster
    Hamster Member
    NW WA
    Fitz' way is what I'm used to. But I also know that the NAPA by me loans tools. Got a NAPA nearby?
  11. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    I used Fitz's thread. Popped the front bearings right out. The double bearings in the rear were a pita. Couldn't get them out. Broke down and bought the tool. As Fitz states in his thread be careful not to mar the inside of the spacer. Spacer burrs will damage the shaft and not allow it to rotate properly. Roc
  12. Hotcakesman
    South Dakota
    I have a mechanic friend.. I will ask him if
    he has an extractor kit.. if not I will go old school
    last night everything I touched turned to you know
    what.. best to walk away and do no more
    damage
  13. schmuckaholic
    California
    The one I did for the writeup (the one I finished after Fitz did his :D) came out without too much difficulty. No telling how long that one had been in there. For all I know, it was original factory. Besides, if we're replacing bearings, I would imagine it's rather unlikely that they're "nice clean new stuff".
    Interesting idea. Hadn't thought of that one.
    Not always possible, sad to say.
  14. ManBot13
    Fairfax, VA
    That was my experience too. The spacer didn't move for me like in Fitz's pic, not matter which side I tried.
    Spacer doesn't rotate in operation, outer surface of the bearing moves with the wheel, the inner stays put with the rest of the axle. However, burrs could jam up the axle in the spacer, making dis-assembly/reassembly difficult. If you burr the surface, simply get a round file and file the burr off before reassembly.
  15. adrian1
    Well not really....the fixed axle is a lot harder than the spacer and won't be scratched by it. Secondly, the wheel is of course hard against the outer bearing race which in turn rotates on the inner race, independent of spacers etc. :wink:
  16. rocs82650
    Middle Tennessee
    Adrian, you're correct. I don't know why I was thinking the spacer rotates on the fixed shaft. Thanks for the correction. Roc
