FS: Intake Boots
Discussion in 'For Sale, Trade/Swap, Wanted' started by SovereignDragon, Jan 28, 2012.
  1. SovereignDragon
    SovereignDragon Member
    Leavenworth, KS
    I've got one set left of carb to head intake boots. They are in decent shape but don't leak. 45 shipped to anywhere in the continental united states.
  2. mooch
    mooch Member
    Dayton, Ohio
    I'm very interested in those as long as you have all 4 and they fit on my 82 xj650. you can PM me and we can talk.
  3. bigfitz52
    BE CAREFUL!
    YICS motor intake manifolds and NON-YICS manifolds are different!
    Manifolds for a pre-YICS ('81~81) ARE NOT compatible with YICS (82~later) motors.
    Pre-YICS manifolds are oriented \ \ \ \ while YICS manifolds are / / \ \.
    They'd bolt on, but your rack wouldn't fit as two of the carb spigots would be pointed in the wrong direction.
  4. hogfiddles
    fitzy is correct.....the left two would be the same, the right two are indeed different. Also, I believe the spacing would be wrong as there is a slight off-set from front to back. If they are put on upside down, they would also be too wide on the right side.....the two right openings would be too far apart from the left two.
    Dave
  5. SovereignDragon
    Leavenworth, KS
    Sorry for the confusion. I knew they were different but a little Captain Morgan and I forgot to mention which ones they are. They are the non YICS. All four of them are clocked the same way when bolted up on the engine.
  6. SovereignDragon
    Leavenworth, KS
    Come on, someone somewhere has to either need a set or want a cheap extra laying around.
