fuel and vac routing to carbs?
Discussion in 'XJ Technical Chat' started by karljesse, Jul 9, 2013.
  1. karljesse
    karljesse Member
    Half Moon Bay, CA
    You folks have been great so far, try this one. I'm not sure my XJ700 was correct when I bought it. I'm trying to figure out where the fuel line (one?) and the vacuum to the petcock, connect to the carbs.
    Right now the fuel goes into a conector between #1 & #2, half way up the air intake. The vacume to petcock is coming from the same location between #3 & #4. Seems odd. The air to the canister is attached to a pipe pointing straight up out of #2. This leaves an unused port on the rod running between all 4 carbs, between #3 and #4. ??? Something doesn't seem right. Can anyone help? Much thanks and I bow to your collective wisdom.
  2. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    CANISTER? do you have a California model XJ700???? dude... I don't know of anyone on here that has one.... I'll have to look in my manual for you....
  3. karljesse
    karljesse Member
    Half Moon Bay, CA
    Yes, this is a CA. bike with a canister. I can't make out this info in the manual I have. Any help on this would make you a super hero!
  4. chacal
    There is a screw-in fitting on the bottom center/rear of the fuel tank that has a vac hose that runs to one port on the vac cannister; the other port on the vac can has a hose that runs to that larger brass vac port on the #2 carb (off to the left side of the mixture screw port boss). If the bike does not have a Cali tank then that fitting on the tank will not be present.
    Vac line from petcock runs to the #2 or #3 intake manifold vac nipple.
    Fuel line runs from petcock to the fuel inlet "T" on the carb bank.
    The bowl overflow/vent hoses (plastic T between 1/2 and 3/4) "run to nowhere", they are open to atmosphere.
  5. hogfiddles
    John...........I have a canister--- :)
    Dave F
  6. karljesse
    karljesse Member
    Half Moon Bay, CA
    You folks are truly sent from heaven. Many thanks!!!
  7. jmilliken
    Dillsburg, PA
  8. jmilliken
    Dillsburg, PA
    Dave, you have everything!
