Fuel Gravity feed for tune up
Discussion in 'XJ Technical Chat' started by dmlyster, Apr 8, 2015.
  1. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Okay, tired of searching for homemade solution thread. I thought there was a thread where someone created a gravity feed solution. I'm in need of a technique to bypass the petcock. Does anyone recall this thread and its location?
    The petcock just needs to be set to prime to bypass the vacuum function. You can prop the fuel tank up, or set it on a suitable support and use a longer fuel line. Some of us use a fuel tank borrowed from a lawn tractor as a remote fuel can.
  3. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Thanks K-moe but that will not work for me, long story. really looking for that thread ..... I know I saw it somewhere.
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
  5. dmlyster
    dmlyster Member
    Corvallis, Oregon
    No, it was more of a contraption, like a plastic bottle or jug that held fuel and drained directly into the carb
  6. k-moe
    You mean like a fuel can that had a barb fitting added to it, or a gear oil bottle that has the bottom cut out has the fuel hose stuffed onto the business end and is hung by wire, or maybe a used fuel tank from a garden tractor? All you need is fuel line, a container, and a way to hook the two together.
    Ignore the links that recommend using pop bottles. They just are not suitable, or safe for transferring gasoline.
    https://www.google.com/search?client=safari&rls=en&q=aux+fuel+site:xjbikes.com&ie=UTF-8&oe=UTF-8
  7. dmlyster
    dmlyster Member
    Corvallis, Oregon
    thanks much K-moe!
  8. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Hey K-Moe, you're really pushing that garden tractor tank option! You a used mower parts salesman or something? laff laff laff!
  9. k-moe
    They are plentiful, cheap, usually come with a petcock, and were meant to feed gas into carbs. The same reasons that Hogfiddles recommends snow machine gas tanks. The most that I ever paid for a used 1 gallon tank was $10, and that was a near pristine one that was for a restoration project.
  10. dmlyster
    dmlyster Member
    Corvallis, Oregon
    I assumed something much larger ..... I'll keep this solution in mind for future projects.
  11. hogfiddles
    I didn't even pay for it .... Just pulled one off a junk machine. The tank hangs on a manhasset music stand base so I can adjust the height if I wish.....
    Here's BluesBass hooking up the tank to a bike for syncing at last June's CNYCC.
  12. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Hmmmmmm
  13. skiprrdog
    skiprrdog Active Member
    Tucson, AZ
  14. MattiThundrrr
    Ahhhh. Now I get what you mean by a music stand. I had read that several times, and was visualizing something waaaay less stable. In my mind the tank was resting on the part where you'd put sheet music. Got it now.
  15. Polock
    if your good, your done before the carbs run dry
    MattiThundrrr likes this.
  16. MattiThundrrr
    If you're me, you look at pictures of others doing it!
  17. hogfiddles
    If you're REALLY good, you can get your whole ride in without a tank
